0 Who runs 70wt. oil
0 1970-71 XL Fuel Tank ?
Last Post: The Doctor71
Last Post: fafcpa
Last Post: SLW210
0 2019 xl1200 suspension upgrade
Last Post: SLW210
0 Diagnostic code ?
Last Post: robbie202
0 A few more filter options
Last Post: Tucsonmax1
0 Oil Leak ??????
Last Post: ftwflh
0 2010 Sporty will not fire! Tried everything, HELP!!!
Last Post: kxrwcer52
0 TSM / TSSM / HFSM - How to disable alarm and/or replace unit
Last Post: caffieneracer
4 greetings from quarantine!
0 XR1200 for trail riding
0 Low Profile Scissors Lift
0 XL Parts '04 up
Last Post: Jcolleyoh
0 '04+ Starting Issues, Do You Have Them? - Poll
0 1960 XLCH in the UK
Last Post: chilly
0 Intake seals, glad I checked them
0 Sportster Tank Art
Last Post: Bryan83taco
0 Why cafe a sportster?
Last Post: Merch131ho
0 Spark Plugs
Last Post: Joe_jeep
ralphy, rpcycle (69), shag (67), roadcapDen (66), oedius (63), Coolride (58), 1965XLCH (54), fingerpie (49), Pacer88888 (48), Smitty001 (42), wiccaboa (42), Homiejaime (34), Popedizzle (31), Moker (17)
Old 6th February 2010
Default '77 & '78 Kick Support
Pics followed by description ...
Pipe is 1,1/4" OD. ID is larger than the 7/8" ID of the holes in the end fittings. I can feel with finger that the pipe has a larger ID than the holes in the fittings on either end. The pipe is probably 1" ID. So pipe is 1/8" thick.
The length of the pipe measured between the two end fittings measures 2,43/64"; so is probably 2,11/16".
The threaded hole in the smaller end fitting is 1/4", same thread as cover bolts. The bolt that goes thru there is 1" in length. Center to center with pipe hole is 1,5/16".
The two unthreaded holes in the case end fitting are 3/8", center to center is 2,11/16". Center to center 1,7/8" and 1,1/8" with the big hole. Check these against the bolts that it mounts to on the case, and against the hole for the shaft.
Cutout hole is 5/8" ID.
Really needs a CAD or whatever drawing to accurately portray the shapes/dimensions of the end fittings.
Vermonter's Avatar
Vermonter Vermonter is offline
Sportster/Buell Year: 1973
Other Motorcycle Model: 80XS650/71CL175/7?gs550
Vermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of light
that should help prevent any case cover cracking.
"If a law is unjust, a man is not only right to disobey it, he is obligated to do so." Thomas Jefferson
Old 7th February 2010
This is a Harley Davidson part that was not included in original bikes from the factory. It is a fix they came up with because of the problem of breaking sprocket covers on these models. Hard to come by, so you may want to make your own. Which is the purpose of this post.
Hopper's Avatar
Hopper Hopper is offline
Other Motorcycle Year: 1942
Back in the Iron Age, before CAD, we used to do drawings by crushing charcoal from the fire at the mouth of the cave and mixing it with our own blood to make ink and using a Dodo bird feather for a quill.
Link to bigger drawing here (I think!):
http://i249.photobucket.com/albums/g...ktcvr005-1.jpg
And not shown on the drawing is this stock divot cut out of the support tube to allow the oil supply line to run through there without being pinched. I had to grind a similar but not so severe divot a little further outboard too, to provide clearance for the 23-tooth sprocket.
66xlch 66xlch is offline
Master Bike Builder
Sportster/Buell Year: 66
Sportster/Buell Model #2: 67 XLH, 63 XLCH
Sportster/Buell Year #2: 67
Other Motorcycle Model: FXRT
Other Motorcycle Year: 91
66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about
I love that part, and I dont know why they only did it for '77-'78s. I broke my '66 cover, and judging by all the welded early covers out there so have lots of others. I'm going to make one for my 'ch for sure.
Hopper's Avatar
Because the 77-78 sprocket cover mountings were even dickier than the earlier models, using 1/4" philips screws made from cheese metal instead of the earlier 5/16 or larger bolts.
See this thread here for how I welded a pad inside my early 77 sprocket cover for this support bracket to attach to. I imagine you could do similar to an earlier model.
This thread:
http://xlforum.net/forums/s...d.php?t=232588
It also shows how I built an extra support bracket from the top of the gearbox where the breather attaches to the top of the sprocket cover for extra support. Could be used on earlier models that break that aluminum mount tag off the top of the gearbox casing.
Master Bike Builder
Yeah, I have one of your later covers in a box somewhere, and it is extra flimsy!
daler daler is offline
Other Motorcycle Model: dyna wideglide
daler is an unknown quantity at this point
Mick, I bought that part from Billscustomcycles.com last year. Seems to me it was about 15-20 bucks. When I installed it I drilled and tapped the 1/4 hole on the support bracket out to 5/16 and then used a 5/16 shoulder bolt for a tight fit thru the cover. Havn't broken a cover since.
Originally Posted by daler View Post
Mick, I bought that part from Billscustomcycles.com last year ...
I got mine from NOSParts.nl. I think i paid at least twice what you did. I don't want to look!
Old 8th February 2010
Hopper's Avatar
I installed it I drilled and tapped the 1/4 hole on the support bracket out to 5/16 and then used a 5/16 shoulder bolt for a tight fit thru the cover..
Yes, I did that too, as well as drilling and tapping the two main mounting bolt holes so I could use 5/16" high-tensile allen head bolts instead of the cheesy 1/4 phillips head screws. Maybe a little bit of overkill - but I dont have estart so the kicker gets a lot of use.
