Last Post: lostNdallas
0 Whats on your head?
0 Fat Bob tanks on a 93 Sportster
Last Post: Dshank14
0 Starter/solenoid issue
Last Post: Dshank14
0 answer with a question game
0 Craiglist finds
0 Misfire 02 883
Last Post: Thegen58
Last Post: 72 Ironhead XLH
0 What engine oil do you use?
Last Post: Clevspeed
0 headlight upgrade
Last Post: Dcoff
5 Harley T-Shirts
0 New handlebar wiring harness 81XLH?
0 Head gasket leak.
Last Post: lucifer_mr2
Last Post: Eddieblz
0 Ever been pulled over?
Last Post: Sprtstr1200s
0 Regulator battery draw
6 Calling all musicians
Last Post: Eddieblz
0 Ran out of gas.
14 Post your Bike in a Cemetary Pic
0 Safe Max Rev Limit stock engine Roadster 2017
Last Post: eduardox23
WinXP (68), Maggie (62), grancan1 (54), SRKASM (48), metalmessiah, o113attitude (44), stinkynate (36), wingman_214 (35)
  #5861
Old 14 Hours Ago
harley506d's Avatar
Sportster/Buell Model: 1200c
Had the 2006 Sporty mostly put together Weds night as stated but for some reason decided not to start it
Last night I remembered I hadn't changed the filter or put oil in it
Changed the oil and added oil
Gave it another once over to be sure I didn't forget anything else
Put the saddle bags on, and fired it up. No unusual noises!!!
Just a thought, did you not fire it up before draining the oil? I ask only because you may have had a load of "sumped" oil that would stay until you fired it up.
Possibly overfilled now?
Old 13 Hours Ago
NLXL's Avatar
NLXL NLXL is offline
NLXL has much to be proud ofNLXL has much to be proud ofNLXL has much to be proud ofNLXL has much to be proud ofNLXL has much to be proud ofNLXL has much to be proud ofNLXL has much to be proud ofNLXL has much to be proud ofNLXL has much to be proud ofNLXL has much to be proud ofNLXL has much to be proud of
I took the breather bolts of and used some CURIL-T (non-hardening seal) on the bolts and between the heads and the filterbox. Thát's were the excessive oil came from and not from the filter. No more messy oil tank, heads and a clean engine again.
I found this solution on this forum by someone who wrote that the breather bolts expand differently than the material the heads are made of. That causes the oil getting through. I can't remember who it was but anyway, if it was you: Thanks for that!
Old 11 Hours Ago
ParrotHead's Avatar
I am the great Cornholio!
Other Motorcycle Year: 1974
I rode it 10 miles before draining the oil
And I checked after it was run and had to add about 1/3 a quart to get it where I like which is in the bottom 1/3 of the dipstick
John Wayne - "The Shootist"
