0 Valve Stem Seal ID
Last Post: BruceM
0 First start question
Last Post: Jaime1840
0 Electrical almost all sorted
Last Post: Ark OB
0 The Little Things - Multi-Part Series on Mods That Make The MOST Difference!
0 Lurker from the SF Bay Area
Last Post: calileo
0 Tank and petcock identification
0 The argument for getting a custom seat
Last Post: BestCoastXL
0 Riding The Badlands in 2021
0 Old School Look
Last Post: Bikeaholic
Last Post: Buellbomb
Last Post: Woody9225
0 Bassani Baffle Supplier
Last Post: GuzziChris
0 The Beat Wife
Last Post: Fifty150
3 Upgrading Trapdoors Bearing (Theory Stage)
Last Post: salmanmr
0 2021 Iron Butt Rally
0 Timing, static or strobe?
irvingjr (73), 909XR (64), Ghost_FL (62), mark R (61), TWISTED (48), spade (46), Drivethis29 (41), dodgetrucken (36)
electrical problems
Old 4 Days Ago
Originally Posted by Gravitas View Post
I carefully tested pushing the new plunger in, with new spring and terminal and jumped it. Success!
I didn't realize THAT is what the bottom of the 1st picture looked like.
So - You replaced the contacts. And the Contactor Ring?
Were the new contacts a different shape?
Did the contactor ring on the plunger now make contact ON THE TOP of both contacts? Not the side.
For Sportster Tech Info:
Old 4 Days Ago
Gravitas Gravitas is offline
Sportster/Buell Year: 1982
Gravitas is an unknown quantity at this point
So - You replaced the contacts. And the Contactor Ring? - Yes(contacts/plunger/spring)
Were the new contacts a different shape? The Starter contact was the same. And there were two other contacts, neither was exactly the same. Either would have been good and I chose one that was vaguely similar shape. The contact is good over a reasonable area and on top.
I can only assume that a previous solenoid upgrade was made and an incorrect contact used. Many thanks for the help and pointers
Old 4 Days Ago
Originally Posted by mikethebike61 View Post
You could solve that by just converting it to a kick start only....
Well If I ever (I guess that is more a when question) have to do a rebuild I could add a kicker, they are not mutually exclusive are they?
Do you also have a Hailwood Replica?
Old 4 Days Ago
AGM is light years better than gel...
Too late! I have the 50 buck gel....
