0 Breaking in a 17-year-old demo
0 Sad day ... Time to learn some more...
0 Lifted 48
7 I met a living legend.
0 Oil in air cleaner
0 Carburetor 101 Float valve question
0 I know I'm gonna catch flack for this...
Last Post: Larry May
0 Wet sumping?
0 Thanks Hammer Performance!
0 a simple question on the grenade plate issue
0 Brake upgrade
Last Post: MatHormell
0 happy or sad memorial day
0 No name carbs.
Last Post: jonesboy
0 Magneto mystery
5 Are you married or single???
Last Post: jcn59
0 My First 100k Miles
0 what brake master cylinder can I use?
Last Post: Roane
0 Amputee Sporty Springer Trike Conversion
0 Share your Sunrise OR Sunset Photos!
0 answer with a question game
0 POTM (Pic Of The Month)
0 .551 Cams in an EFI 1200
Last Post: Akdawg
Last Post: XLPIZZA
  #201
Old 1st September 2018
BKB's Avatar
BKB BKB is offline
Hey!! Stop hatin on the Gremlin!! I had a '73 Levis edition that I got 8 years & 180,000 miles out of before I crashed it. Loved that car. 232 6 cylinder, 3 speed. Put a set of Hooker headers, dual exhausts, an Offy aluminum intake & a Carter AFB 4 barrel carb. Built the suspension & brakes to match. Fun car to drive & didn't have any problem finding it in a parking lot.
Brian '09 1200C (black of course), 19" front wheel, det. windshield, Sundowner, mini apes, Big Sucker, x14IEDs, 12.5" Progressive 412's, Intiminators, Gronk mod
Graywolf Graywolf is offline
I can see where there could be some advantages to owning a Gremlin........... like never having to worry about it getting stolen!
Graywolf
Old 2nd September 2018
Medyo Bastos Medyo Bastos is offline
Sportster/Buell Year: 1966
Medyo Bastos is an unknown quantity at this point
I was a javelin owner
Toejam503's Avatar
Toejam503 Toejam503 is online now
Air-Cooled Forever
Sportster/Buell Year #2: 1981
Originally Posted by Glamazon View Post
That is a horrid coloured Maverick! I go to car shows & enjoy looking at American cars but I've never seen a Maverick in the metal. Were they so bad no one thinks they're worth saving?
Found these 2 examples of unloved American cars at a local American car/bike/rock n roll meet. A Plymouth Volare Roadrunner & a Ford Pinto https://scontent-lht6-1.xx.fbcdn.net...da&oe=5C2861F4
They still make the Maverick in Brazil with the same tooling, not available for export.
ZCarFan ZCarFan is online now
ZCarFan has a brilliant futureZCarFan has a brilliant futureZCarFan has a brilliant futureZCarFan has a brilliant futureZCarFan has a brilliant futureZCarFan has a brilliant futureZCarFan has a brilliant futureZCarFan has a brilliant futureZCarFan has a brilliant futureZCarFan has a brilliant futureZCarFan has a brilliant future
Worst one I ever had was a '78 Mercedes 280SE. Not really the car's fault but all of the previous owners. Finally got the fuel system cleaned out and running OK then I put it in reverse to back up. Nothing! Sent out for scrap. Still have an 84 280SE that at least runs but same problem... clueless POs broke more than they fixed. Nothing more expensive than a cheap Mercedes but I'm a sucker for DOHC inline sixes.
Second place goes to the '82 Chevy LUV 4x4 Diesel I had. It takes a real sense of humor running around in a 50HP truck. So rusty it nearly broke in half on an interstate overpass. frame cracked on both sides above the forward leaf spring mounts. Just a thin strip on top of both rails and all the hoses etc holding it together. Threw the hazard lights on and drive it at about 20 mph the 4-5 miles to my friend's house with the driveshaft rubbing something under there and wiggling around like spaghetti. That one takes second place because I at least got to drive it a year before it's demise.
Old 6th September 2018
very early vw beetle, whopping 25 hp and ran 45mph. wore out crank, never could get it shimmed right so the crank walked and the seal would not hold up. stupid design used paper shims, either too tight and locked or too loose and leaked.
second was a vw dasher, had to rebuild the diff'l at early mileage and had bad head under recall.
Old 8th September 2018
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
Volvo 340 GL; similar to this:
Absolutely awful car! It was a long slow slog to get the thing moving at all, it cornered like a pregnant elephant (with arthritis!), and the brakes were virtually non existent. Apart from that, it wasn't too bad!
Folkie
South East England Riders
DEEP DIVER's Avatar
Sportster/Buell Year: 1984
Sportster/Buell Year #2: 1993
Other Motorcycle Year: 1984
Mine was a Vauxhall Chevette 3 door. Only had it 6 months and in that time had the head gasket, starter motor, alternator, coil, distributor and steer joints.
It leaked water on to the floor so the carpets were wet and the floor was rotten. I will never have another Vauxhall again.
Old 23rd September 2018
the amc gremlins were wayyyy better than the chevy chevette and vega.
at least the engines held up, amc was known as a cancer-mobile. the chevy aluminum block was doing good to get 30k as most were toast when the heat treat on the bores failed.
the ford pinto with the canada iron duke was a good car except for the fuel tank top being the trunk floor and was a fire/explosion hazard.
Yakcm2's Avatar
Yakcm2 Yakcm2 is offline
Sportster/Buell Model: XLS 1000 Roadster
Sportster/Buell Year: 1982
Yakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond repute
Got a wild hair one year and followed a women to upstate New York, once there I needed a car so this guy I meet says I gotta car for ya, a pea green 68 Dodge Dart, 225 slant six that ran on 5 cylinders and the rust in the trunk was so bad that the rear leaf spring shackles broke through the floor of said trunk and the guys fix for it was too shove a 4x4 piece of lumber between the leaf springs and the bottom of the trunk and secured it to the springs with clothesline cord and wire,
All that for the discount price of $200. It lasted about a month.
and that's my 2cents worth...
Similar Threads
OIL CHANGE!!! IrishThug Dealers, Stealers, Indys and Parts Dealers 26 26th April 2005 19:00
Mirrors: How important is it to see behind you? KLars Sportster Motorcycle General Discussion and Problems 37 8th April 2005 16:09
