0 Piston size id?
0 Knocking noise in front cylinder!!!!
Last Post: Rossline
0 Forum problems???
5 Harley T-Shirts
0 Age limit where belts should be replaced?
6 Hello from Central Vermont
Last Post: JonW.
0 '06 Sporster Oil Tank drain
0 Fuel Pump Problems
0 Old Parts
Last Post: Hopalong48
3 Ironhead Pictures Thread
Last Post: Island Dude
0 1979 XLH Carb
0 Hello from Murcia-SPAIN
0 Gibt es hier keine Deutschen?
Last Post: Clementine
0 Hello from Germany
0 Operation Live Wire
Last Post: WI_duker
0 Need recommendations for 17"/18" Wheels (or maybe 19..)
Last Post: Edster
0 Trip to Rockies
Last Post: Blues
0 Magnetos
Last Post: Scott
0 Nothing much
Last Post: 83ironman
0 Oil Analysis?
0 electronic ignition
hubbinator (70), sport53 (66), kship (54), jrmkel (40), IR88n3 (35), waltweezy45 (32), lumberjack (29)
hammer performance, koso, ricor
  #51
Old 20th May 2012
PiousDevil's Avatar
PiousDevil PiousDevil is offline
Sportster/Buell Model: 883->HP1250
PiousDevil has a brilliant futurePiousDevil has a brilliant futurePiousDevil has a brilliant futurePiousDevil has a brilliant futurePiousDevil has a brilliant futurePiousDevil has a brilliant futurePiousDevil has a brilliant futurePiousDevil has a brilliant futurePiousDevil has a brilliant futurePiousDevil has a brilliant futurePiousDevil has a brilliant future
Why do those pushrod covers look warped towards the bottom?
Always thinking 360°
Old 20th May 2012
jessearias's Avatar
jessearias jessearias is offline
Sportster/Buell Model #2: XR-1000
Sportster/Buell Year #2: 1984
jessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nice
Default JUst remove rocker poxes
Sometimes the seal or o-rings get pinched and/or don't seat right when you install the pushrod tubes and they start leaking. You may just need some new o-rings and fit it together again. I always lube the crap out of my o-rings and tubes w/ STP so they slip together easy and don't pinch.
You should only need to remove the rocker boxes so, you can move the pushrods out of the way to put new o-rings and gaskets on the lifter guide bases.
Much easier than pulling the whole thing apart.
I use the NRHS Colapable Pushrod tube kit with no leakage problems.
[FONT="Arial"] Jesse :smoke [/FONT]
2002 XL1200S "The Black Beauty" NRHS 1250 kit CI, NRHS Stage 1 TS heads dual plugged, NRHS Hurricane Air Filter, SE 536 cams, Rich Products Thunder header, 42 Mikuni, Daytona Twin Tec ignition w/ Dyna coils. 97.4 HP, 85.5 Torque 1984 XR-1000 S&S Crank/rods w/windage tray, Vision Grinding Cylinders, Arias 11:1 compression pistons, Andrews XR-1000-1 cams, Baisley modified dual plugged heads, Rich Products Thunder header, 38mm Delortos, Daytona Twin Tec ignition w/ Dyna coils. (the never ending project but, got a 66 Barracuda drag car sucking up all the funds and time)
Old 21st May 2012
goblin_dust's Avatar
goblin_dust goblin_dust is offline
Sportster/Buell Model #2: XR1200
goblin_dust is a splendid one to beholdgoblin_dust is a splendid one to beholdgoblin_dust is a splendid one to beholdgoblin_dust is a splendid one to beholdgoblin_dust is a splendid one to beholdgoblin_dust is a splendid one to beholdgoblin_dust is a splendid one to beholdgoblin_dust is a splendid one to beholdgoblin_dust is a splendid one to beholdgoblin_dust is a splendid one to beholdgoblin_dust is a splendid one to behold
I thought I lubricated then well. I guess I'll know when I take it apart again.
