11th May 2015
good luck finding W cams from a pre-2000. Those are about as rare as hens teeth.
11th May 2015
Posts: 20,734 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2006 Sportster/Buell Model #2: XL1200C Sportster/Buell Year #2: 2006 Other Motorcycle Model: 48 "Totalled" By a Douche Other Motorcycle Year: 2012
Only came is the "S" model I think
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
11th May 2015
that is correct and 1999 and under S models are quite rare bikes.
11th May 2015
Will N4's work with some head work ?
11th May 2015
Posts: 278 Sportster/Buell Model: ironhead xlch Sportster/Buell Year: 74 Sportster/Buell Model #2: xlh Sportster/Buell Year #2: 1976 Other Motorcycle Model: xlx Other Motorcycle Year: 1984
If I remember the best quick bang of the buc bolt on is gettin buell heads. and 98 99 harley DID dual plug the sporty 1200s... definately the makings of a rice killer
11th May 2015
Posts: 1,274 Sportster/Buell Model: XLH HAMMER 1250 Sportster/Buell Year: 1995
I got 87 HP with my N4s & stage 1 head work on Buell Lightning heads
11th May 2015
N4s will work even without headwork but you will get more power if you do.
11th May 2015
Posts: 8 Sportster/Buell Model: 883XL Sportster/Buell Year: 1999
What size cams should I be looking to get with the stock heads? Should I go with different pistons if I go with new cams? I'm quite a novice so I don know if I would have toget the heads machined if I get new heads as well.
11th May 2015
The N4 cams would be a good choice. They are a bolt in cam set.
11th May 2015
the way I understand it, you will get the best results by matching all the engine components to the cams. Figure out what cams would be the best for your needs & go from there. The N4s were a good cam but I don't think they are a 100HP cam
