Last Post: SLW210
0 Stepped headers vs single diameter headers
0 Winter reading........
0 Cafe or sport faing on xl1200cx?
Last Post: ORCX
Last Post: ZCarFan
0 Amputee Sporty Springer Trike Conversion
0 Trackday Sportster
0 A Separate Speedo and Tach
0 02 sensor query
0 How much should I offer for this 48
5 my 3D printed turn signals.. what would you print?
Last Post: hitchcme
0 Forum problems???
0 1998 Sportster Sport 1200s cam choice
Last Post: tattooglisha
5 Terminology Sticky?
0 compression problems
0 XB9 crank?
Last Post: Edster
Last Post: WI_duker
0 Hello from Murcia-SPAIN
Last Post: heyshott 81
fhilliard (78), paulmo (74), Beloved (48), Mr. Cro (48), Chopper Duke (40), Danny3nose (38)
Old 16th August 2016
vlmuke's Avatar
vlmuke vlmuke is offline
Other Motorcycle Model: Fat Bob
Other Motorcycle Year: 2015
vlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to behold
Default 07 Beetle Clutch slipping stalling after driving thru water
Looking help ideas on what to look for, my GF's 07 VW Beetle, we had a bunch of rain like most of the country, drove the car thru a puddle that went almost up to her doors, after that she claims it wants to stall/ clutch slipping in 1 and 2nd gear, car is 5 speed manual, after that it runs fine in the remaining gears, I am out of town for work and will be home later, looking for ideas on what it could be Thanks,
I don't know it all Nor do I claim to
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Give it time to dry out first.Clutch fibers slip when water logged.
It is OK in later gears because the clutch is not having to grab so hard when the car is up to speed.
sportsterdoc's Avatar
I can understand slipping if water had some oil in it.
Never had a clutch effected by driving through water. 09 Toyota (manual 5 speed 4WD) went through 20"-22" at stream crossing near ranch a few times..and water was a bit muddy.
Don't understand the stalling relating to the clutch...or is the motor stalling/running rough?
rokytnji's Avatar
If a mainshaft seal is leaking oil into the clutch plate. I guess water would make things seem worse. In that case. No quick fix.
vlmuke's Avatar
See I don't know I am about 100 miles away and will be home later tonight, at 0 dark thirty, See thats what perplexes me too, as I asked her if its slipping or stalling she said both, I asked how it runs in the higher gears and she claims fine, I don't think the thing has a distributor, So I don't know if the thing got water somewhere, I figure the thing was mostly waterproof, I mean not to the extent of playing u-boat.
vlmuke's Avatar
it doesn't leak oil anywhere, only 60k miles, I was kinda thinking along the lines of your initial reply as it may have gotten water on the fiber plate seemed logical to me as well
Old 17th August 2016
Did she disengage the clutch while driving through the deep water?
All my stream crossings were in 4LO with clutch fully engaged.
Green hornet's Avatar
Green hornet Green hornet is offline
Sportster/Buell Model: Sportster 72
Other Motorcycle Model: Honda CBR 1000RR DragBike
Green hornet has disabled reputation
Vw's are notorious for running bad after getting wet. At my shop we usually give dirty motors a quick blast with the power washer before delivery. We never do it to any VW because they always run like crap until they dry off. I am willing to bet it will run fine in a couple of days.
Old 18th August 2016
I have to get out of the beetle air cool mine set as that is where my experience lies. I assume it is an water cooler engine so like was brought out, water in a sensor harness like the crank angle. this would cause bucking and when clutching also, can do as described. since the main seal is behind the flywheel, there will be tells of a leak and it would have to be a good one and over time to coat the clutch lining. there is one thing that comes to mind, went through the issue on a ford. the throw out assy is pure junk plastic and if sand/dirt was washed into the sliding parts, it could cause sticking and plastic is self destructive so one done, always done.
Old 24th August 2016
vlmuke's Avatar
Sorry to take so long to reply back, as I have been hardly home for work and tapatalk isn't working, But anyway when I got home I couldn't find anywhere water could get into the clutch area so, each time she drove it, the problem seemed to dimish, so its running great but she seems to think it shifts a little stiff now so, I am going to see if I can lube the shifter and if there is any sort of linkage and see what happens.
