0 Knocking noise in front cylinder!!!!
Last Post: Rossline
0 Forum problems???
5 Harley T-Shirts
0 Age limit where belts should be replaced?
6 Hello from Central Vermont
Last Post: JonW.
0 '06 Sporster Oil Tank drain
0 Fuel Pump Problems
0 Old Parts
Last Post: Hopalong48
3 Ironhead Pictures Thread
Last Post: Island Dude
0 1979 XLH Carb
0 Hello from Murcia-SPAIN
0 Gibt es hier keine Deutschen?
Last Post: Clementine
0 Hello from Germany
0 Operation Live Wire
Last Post: WI_duker
0 Need recommendations for 17"/18" Wheels (or maybe 19..)
Last Post: Edster
0 Trip to Rockies
Last Post: Blues
0 Magnetos
Last Post: Scott
0 Nothing much
Last Post: 83ironman
0 Oil Analysis?
0 electronic ignition
0 Piston size id?
hubbinator (70), sport53 (66), kship (54), jrmkel (40), IR88n3 (35), waltweezy45 (32), lumberjack (29)
Old 14th September 2017
jimmyess333's Avatar
jimmyess333 jimmyess333 is offline
Sportster/Buell Model: none
Sportster/Buell Year: 0
jimmyess333 is a splendid one to beholdjimmyess333 is a splendid one to beholdjimmyess333 is a splendid one to beholdjimmyess333 is a splendid one to beholdjimmyess333 is a splendid one to beholdjimmyess333 is a splendid one to beholdjimmyess333 is a splendid one to beholdjimmyess333 is a splendid one to beholdjimmyess333 is a splendid one to beholdjimmyess333 is a splendid one to beholdjimmyess333 is a splendid one to behold
Default Can I have a standard oil pump converted to high volume?
There is no high volume oil pump available for the engine I want to install one on (1988-2001 Chrysler 3.0 V6).
Is there a service that converts stock oil pumps to high volume?
sportsterdoc's Avatar
Is the 3.0 made by Mitsubishi for Chrysler?
What is current volume?
What is your target volume?
Yes, that's the engine.
The engine has high miles but runs great and doesn't burn oil.
I put rebuilt heads on it last year because it had a bad a bad valve, bad valve seals, and a couple of bad lifters. I also cleaned out all the carbon while I was in there.
The oil pressure is at 4psi idling when the engine is hot.
I feel like it should be closer to 10psi...it was like this before the headwork and it's still the same. I think this might have contributed to the bad lifters.
It's a little cooler today. I'm getting a fluctuation of 6-7psi at idle when hot.
I'm thinking the crank bearings have some wear and that's where I'm losing some psi.
Old 15th September 2017
Sorry for the delay in response, but just got back from Death Valley.
Maybe you may want a new oil pump, but I have no info on a high output unit.
I was thinking of that too, maybe a new stock pump and pickup if I can't find a high volume.
