0 Locked up '72
Last Post: fastxl1250
Last Post: fafcpa
0 Major update forthcoming
Last Post: bplinson
0 Belt tension
0 C.O.B.B. Spring 2024
3 Ironhead Pictures Thread
0 Happy Hanukah
0 Ironhead Exhaust Poll
Last Post: Gearhead88
0 65 xlch
Last Post: PReed4859
0 Mosey, where you at?
Last Post: MDT
0 1970-71 cylinders
0 Brand New '78 Sportster
0 Cylinder Date Codes
0 New tyre
Last Post: bplinson
0 What a ride it's been
Last Post: Screw Loose Dan
0 Did your ECM break?
Last Post: Sportzilla
0 Anybody here ride a pocket valve?
Last Post: bill smith
Last Post: mvent
0 No Start conditions
0 Should I buy a Sportster??
Last Post: IronHeadRon
lineberger, 39dan (65), FstPig (64), jmdajd (60), ironhead 74 (60), erjasn84, Bada Bing (59), ottchuck (58), OutlawTexan67 (56), RAJ (50), Wintersdark (47), robychopper (47), TnsporT (46), MotoSquirrel (39)
Old 28th May 2023
Steve S. Steve S. is offline
Steve S. is an unknown quantity at this point
Default Need Help Installing Mid-USA Distributor
Anyone have any experience with these distributors? I have one I'm putting in a 1968 XLCH and I'm not sure how to install it since there's no Cam Timing Mark on the breaker Cam.
Any suggestions? Sorry I don't know how to post pictures on here.
Thank you.
Old 28th May 2023
sungod's Avatar
sungod sungod is offline
Sportster/Buell Year: 1970
Sportster/Buell Year #2: 1973
Are you installing 17055?
Points type?
Old 28th May 2023
Yes. Fits 56-70 Harley. Thanks.
Old 28th May 2023
sungod's Avatar
So I believe the procedure is typical for your new distributor vs the stock unit or mag. Here is a quick overview ps the timing mark on the lobe is not a deal breaker for you. FSM will be helpful.
Set point gap on both lobes.
Remove spark plugs and rotate engine until front cylinder is on compression stroke and you see the timing mark in the center of the hole.
Now you notice the breaker spiral gear will turn the lobes when you install into the case.
You want the small lobe (front cylinder) close to lifting the fiber arm and opening the points. Close is all you want at this point.
Once the unit is fully down turn the lobe clockwise to full advance and now turn the unit body to have the point fiber arm just open the points on the small lobe.
Lock down unit and rotate the engine a few times.
Recheck point gap both lobes and watch for proper operation and also lube the lobes.
Timing plug back in and spark plugs installed wires on.
Make sure all screws are tight and try to start.
Old 28th May 2023
What happened to the original magneto??
Old 28th May 2023
Thank you sungod. That's exactly what I did so I appreciate your very detailed reply. Exactly what I needed.
One question. When you say "small lobe" you're referring to the lobe that is more narrow and "pointy"
Correct?
Thank you!
Steve
Old 28th May 2023
kitabel kitabel is offline
Sportster/Buell Year: 1989
That breaker (and any other suitable for early XL) also fits:
1937-73 W, WL, WLA, WLC, WLDR, WR, G, GA, GE
1952-56 K, KK, KH, KHK
1937-48 U, UL, UH, ULH
Old 28th May 2023
sungod's Avatar
Correct?
Thank you!
Steve
Yes the small lobe(narrow pointy) is the front cylinder.
Old 29th May 2023
Thanks again. She fired right up with four kicks!
