0 Locked up '72
0 Ironhead Sprocket Covers
0 Any tricks for ground cable?
0 C.O.B.B. Spring 2024
3 Ironhead Pictures Thread
Last Post: 83XLX
0 Cyber Monday Week Savings - 2 Different Savings Codes!
0 Clutch Cable
Last Post: sifty
0 Torque values
0 15% Off 1275 Packages through 12/4!
0 2021 HD sportster 48 front brake light switch fail causing brake lights always on
Last Post: ivanford
0 Bolt for Mid Control sprocket?
Last Post: Debute23
0 No Start conditions
Last Post: Harley Quinn
0 Mystery Cases
Last Post: Crom13
0 Popping
Last Post: JB in NC
0 A different kind of question on 65-A
Last Post: bill smith
Old 25th May 2023
Yochstein Yochstein is offline
Sportster/Buell Model: XLH Sportster
Sportster/Buell Year: 1984
Yochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud of
Default Highway Pegs recommendation
I'm seriously considering reverting back to mid controls but having forward pegs for extended rides. Anyone have a recommendation for what highway peg set would bolt up to the late '84 frame that would not interfere with the exhaust?
Old 25th May 2023
ericfreeman's Avatar
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
ericfreeman has a reputation beyond reputeericfreeman has a reputation beyond reputeericfreeman has a reputation beyond reputeericfreeman has a reputation beyond reputeericfreeman has a reputation beyond reputeericfreeman has a reputation beyond reputeericfreeman has a reputation beyond reputeericfreeman has a reputation beyond reputeericfreeman has a reputation beyond reputeericfreeman has a reputation beyond reputeericfreeman has a reputation beyond repute
I had to modify some V-Twin highwaypegs to bring them back a little for my short legs. The normal kit had the chrome bracket that hung the pegs out in front of the exhaust and it was a reach for me. I found that I could make an offset bracket that the bent peg mounting bar would bolt to that also fit a hole in the motor mount and let the peg slip between the cam cover and the exhaust pipe. Perfect fit for my legs and gives me that great ability to stretch the old legs nwhen needed.
I can get you some pics that show my setup but will have to wait until the weekend (bikes are in a storage garage right now).
Old 25th May 2023
Dusz Dusz is offline
Dusz
Sportster/Buell Model: XL883L
Dusz has a reputation beyond reputeDusz has a reputation beyond reputeDusz has a reputation beyond reputeDusz has a reputation beyond reputeDusz has a reputation beyond reputeDusz has a reputation beyond reputeDusz has a reputation beyond reputeDusz has a reputation beyond reputeDusz has a reputation beyond reputeDusz has a reputation beyond reputeDusz has a reputation beyond repute
My Super Low had the mids as standard and I considered changing to forward controls. I bought a cheap set of forward controls and fitted just the pegs to try out the position before changing the linkage. In the end I didn't fit the linkages only the pegs. I can stretch out when I want to on longer runs.
So, why not keep the forward control pegs and just delete the linkages to the gear change and rear master cylinder then install the mids. Saves you a bit of money and you know where the pegs are already.
Old 29th May 2023
Wow, I never thought of that!
