0 1970-71 cylinders
0 Access of the site from Spain
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: keithnh
3 Ironhead Pictures Thread
0 Locked up '72
0 C.O.B.B. Spring 2024
0 Ironhead Sprocket Covers
0 Any tricks for ground cable?
0 Cyber Monday Week Savings - 2 Different Savings Codes!
0 Clutch Cable
Last Post: sifty
0 Torque values
0 15% Off 1275 Packages through 12/4!
0 Bolt for Mid Control sprocket?
Last Post: Debute23
0 No Start conditions
Last Post: Harley Quinn
0 Mystery Cases
Last Post: Crom13
Old 2nd October 2023
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Other Motorcycle Model: BMW K1200RS,
Default MX rear wheel
Has anyone on here every run a MX rear wheel/hub with street tire behind a Sportster?
Looking at putting a set on a lightweight mild Ironhead. Curious how the hub drive side held up.
I would be using one from a modern day large bore, but have concerns about the difference in torque, and what it may do to the hub.
The original bike has similar hp numbers, but torque is a bit lower, although not much.
Anyone with any experiences??
Thanks
cannot say that i have but are you talking about off road and dirt wheels?
if so i do not think you will have an issue since you will not be loading up the wheel unless of course you are going off road sports.
Not so much concerned with the off roading aspect as much as tearing the sprocket bolts out of the hub, and/or wiping out the drive side bearing.
I have a few sets of wheels and am building an xr’ish Ironhead for my sons street bike. I want to keep it as light as possible.
Mild 900 w/P cams. Not an abundance of power, but a bit more applied torque than the wheels are intended for (not by much).
Apologies, yes I mean “dirt bike wheels and hubs”
