25th September 2023
Posts: 9,545 Sportster/Buell Model: XLB, XLCH, Sporton Sportster/Buell Year: 1962 Sportster/Buell Model #2: XLCH Sportster/Buell Year #2: 1966 Other Motorcycle Model: XLCH (Another one) Other Motorcycle Year: 1966
OK. Carbs 101.
I think I told you earlier on that almost any carb can be made to work. And that's true. But there are limitations.
If you do your carb selection carefully you'll begin with ventiri size. Size is not the only determinate of flow which is what we really want to know. Dome carb designs are better than others when it comes to flow. Butterfly carbs (S&S Tilly, Linkert etc) have an obstruction in the air flow, the butterfly (valve) itself.
Other designs, round and flat slide carbs lift this valve out of the way at WOT. Albeit at the expense of "camels" through the venturi and the needle. These things were addressed in "Smoothbore" versions and Amal's RN (Renate Needle) carbs.
What that means is for a given size, say 40mm one type of carb may flow more than another at WOT.
Why are we concerned about this ?
Well, an engine needs a certain amount of air to run at it's peak performance. So the first step in determining what carb you SHOULD run is, how much air flow does my engine need to run correctly at WOT ?
You can then make a valid comparison to available carbs to see which ones will work and which ones won't.
NOTE: You don't want to just grab the biggest carb you can. Because velocity of the air through the carb is also very important. At part throttle openings the flow rate falls off and if it falls below a certain point fuel mixture doesn't happen correctly.
So, ideally what you want is the carb that flows just enough at WOT.
Well, unless your willing to sacrifice some power in the top end.
You'll notice trials type bikes have carbs that are clearly too small for the engine. But they don't give a damn about top end performance I digress.
Bigger engines (capacity) requires more air flow.. That's exactly why the S&S came into being. Drag racers were being hampered by the small venturi the Linkert offered. A bigger Linkert was needed.
So, to begin with, your Mikuni VM 38 ihas a 38 mm venturi. The S&S has a 45mm venturi.
Once you get past the initial selection you have to "jet" the carb for the entire rev range. Each "circuit" ( dile, inter, main etc) will be controlled in some fashion. Mostly different sized jets. These jets provide a "metered" amount of fuel flow at given pressures.
It's up to whoever fits whatever carb to whatever engine to determine the correct jet sizes/settings.
You CANNOT just pull a carb off the shelf, from the pile, off eBay and expect it work correctly. It's not going to.
How do you determine which jets/settings are the right ones ?
Well, that's up to you. You can:
1. Ask your mates what they are running.
2. Guess
3. "Seat of the pants" testing
4. Plug "reading".
5 Do it properly.
4 of those methods will give you a result of some sort. The 5th will get it correct. (As good as it gets)
25th September 2023
Edit (of sorts)
All of the above is of course just my opinion. Others may disagree.
I base it on 40 odd years of road racing different bikes. But I could still be wrong.
25th September 2023
Oh.
(After reading Jim's Post)
I use a simple "diagnostic" tool. Abnout $60 off eBay. A "fake" S*S super E. Buy a new one for your model of bike. It will come jetted for a stock engine. It will work well in most cases.
Drop it on and tun the bike with it.
Have a look at what jets are in there. If the S&S doesn't have the same numbered jets as yours change them over. (or leave the fake on there)
25th September 2023
Posts: 551 Sportster/Buell Model: XL 1200 Sportster/Buell Year: 2000 Sportster/Buell Model #2: XL 1200 Sportster/Buell Year #2: 1993 Other Motorcycle Model: H-D FLH Other Motorcycle Year: 1980
Originally Posted by Ferrous Head
Edit (of sorts)
Your point about correct venturi size is often overlooked. Case in point, I had a '76 FXE that came to me with a Super E, and it ran fine. In the course of tinkering with it over a number of years, I found the correct Keihin for it at a swap meet (for $10) and rebuilt and installed that as an experiment. The bike ran just the same with the smaller carb, because its venturi size was adequate for a 74 cu.in. motor.
Jim
25th September 2023
S&S will tell you the Super B (E) will work on engines up to 90 inches.
I think they're a bit optimistic. Nut they will certainly wok on an 84 incher.
And some engines need more. And some less.
Stock IH's flow around 155 CFM (This is from my memory, so grain of salt). The ones on my race engine flow 155.
The Super B is rated around 168-170 (again. my memory).
So with stock heads a Kehein flowing 125 will be fine. The Super b is in fact too big.
To get optimums everything needs to be correct. near enough will also work, but if you want to go racing it's never good enough.
Street performance really follows race performance as well. Don't expect any old carb with any old settings to work correctly.
3rd October 2023
Posts: 70 Sportster/Buell Model: Ironhead Sportster/Buell Year: 80
I ended up putting the keihin back on the bike. Works as well as it could, starts right up, runs etc. so I’m fine there. I ran into an older guy who rides iron heads who told me “that bike should pop into neutral with NO PROBLEMS!” Well, I went looking for it, trying to adjust it better and getting it so that it would slide into neutral at a stop. Now I can’t get it back to where it was(it was working pretty good). Without taking off the primary cover, I just can’t tell when the ball bearings are seated in the inner and outer detentes. Is there a trick for this? As I have it, the throw is too long and the bearings pop out of their seats and I hear a “pop” then no clutch…
3rd October 2023
You have too much clearance at the adjustment screw. In the absence of a sense of feel for the position of that screw, tighten up the adjustment 1/4 turn and try it. (You will of course have to do a cable adjustment after the screw adjustment; the cable adjustment should always be the last adjustment that you do.)
If that quarter turn does not eliminate the balls popping out of their ramps, go another quarter turn.
Jim
3rd October 2023
But then the bike wants to creep forward with the clutch pulled in. I think there’s a “sweet spot” that I just can’t find
3rd October 2023
Posts: 2,090 Sportster/Buell Model: xlh Sportster/Buell Year: 1974
Originally Posted by JB in NC
.. the cable adjustment should always be the last adjustment that you do.)
I have no doubt that Jim can make a clutch work. If his method deviates from the manual instructions but it works , then of course it's all good.
But,
Here's a link to a copy of the manual instructions.
Step 3 insures that the mechanism and balls are positioned correctly.
Then adjust all slack out of the cable.
When done there is NO MORE cable adjusting.
Then set the adjusting screw.
The amount that the screw is backed out is what determines the amount of free play at the lever.
It works for me. Good luck.
http://xlforum.net/forums/showpost.p...9&postcount=66
3rd October 2023
The LAST adjustment is the cable adjustment.
Step 5, last sentence: "If incorrect, adjust sleeve and tighten locknut." (The sleeve adjustment in this sentence refers to the cable adjusting sleeve.)
I don't like trying to make the final adjustment at the clutch, because a small movement of the screw causes a large difference at the cable (hand lever).
Jim
