0 Newbie seeks smoother ride
0 valve seals?
0 my sunday driver...
Last Post: commando57
0 Secret Australian Business
0 Chain Problems-'90XLH
Last Post: Four Speed
0 Colorado Trike
0 It's stalkie's Birthday!
Last Post: canoli
0 Tragic MC Museum Fire
Last Post: sprink
0 1275 or 88 or 90 CID for 4-Speed
0 Lifespan for Shorai LiFePO4 Battery?
0 Clutch spring question
Last Post: JonesL
0 Boardtracker Project
Last Post: JonesL
0 looking for controls
Last Post: schaffersshovel
0 Flat Tracker Conversion
Last Post: 45Brit
0 Removing Rear Shock
Last Post: 45Brit
0 Pistol Braces
0 gas tank Quick connect leaking
Last Post: packdog
Last Post: 109Countries
jurneyman (79), AdO650 (65), xlsport (63), darth (60), mcsmokinp (56), stalkie (56), unleashed66 (55), 66xlch (55), lownslow (49), hrg (47), Ironduke (45)
  #231
Old 11th January 2020
doodah man's Avatar
Have you seen this old post?
http://xlforum.net/forums/showpost.p...1&postcount=21
spamer80 spamer80 is offline
Sportster/Buell Model: XLX1000-61
spamer80 is a name known to allspamer80 is a name known to allspamer80 is a name known to allspamer80 is a name known to allspamer80 is a name known to allspamer80 is a name known to allspamer80 is a name known to allspamer80 is a name known to allspamer80 is a name known to allspamer80 is a name known to allspamer80 is a name known to all
Originally Posted by doodah man View Post
Yes, thank you. The new rollers are still on their way anyway. And I'm pretty bad when it comes to any precise things (like drilling). So when it's possible to do anything with specified tool, I'm doing it with tools.
Just don't want the drill to "walk" and somehow damage the tappet body.
Old 13th January 2020
I have found that lifters that are in need of new rollers often have wear on the bodies and holder bore and are not worth installing a new roller in. And any holder that has been through roller damage is also damaged on the flats that steer the roller and are not repairable or re-useable. The soft aluminum holders get hard bits of debris embedded in them and then the lifter moving against it wears out like it was being ground on.
I Buy new lifters and holders, or oversize lifters and bore the holders to accept them.
Oil with gas in it is a lifters worst enemy, followed by hot environmentally friendly oil (no or low zinc) then dirty oil. The new environmentally friendly oils (anything newer than SH rating) are not formulated for use in your Harley.
Old 14th January 2020
Yeah, I know about oil, thank you. When I bought this bike, i went to home from Moscow to Saint-Petersburg on it. 500 miles. Then changed oil immediately. Something green was there. It was already all noisy, so probably it was partially the cause of lifters bearings and cylinders honing end.
I've used Castrol 20w50 4t motorcycle mineral oil since then.
Now I'm going to switch to Liqui Moly hd classic sae50.
And about new lifters - i thought about it but I can't find any good for the price.
Some says Jims are ok, but some says it's already Taiwan now too.
SHAKY DAVE's Avatar
SHAKY DAVE SHAKY DAVE is offline
Sportster/Buell Year: 83
Sportster/Buell Year #2: xlh
SHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to all
I run jims and they are really good.over 50000 miles on them and virtually no wear.i've absolutely never heard about anything that jims has parts made in Taiwan.call them and find out for yourself and let us know
As long as they are made to spec and no mystery metal used, who cares where they come from?
Old 15th January 2020
Well, $400 for tappets is too big hit for my pocket these days. Do you think they worth it?
So, can you tell the best overall for price/quality? Just your personal opinion.
I'd have to trust Jim's.
Or ask Baisley next time I stumble in there.
Old 16th January 2020
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
i have installed lots of Eastern rollers in a PM scenario with no ill results. Inexpensive and simple to install.
