0 75 IH Oil leaking into starter from primary side/ bendix
Last Post: BelleBanger
0 Any experience with REBUILT title?
Last Post: 84bobber
0 Boardtracker Project
0 Smoke and top end job
0 v twin Crankshaft Bushing Plate Pilot and Reamer
Last Post: thecarfarmer
Last Post: psycho69
0 Clearance between clutch faces 1974 transmission
0 Pinion shaft roller bearing plug fit
Last Post: Jaime1840
Last Post: rider61
0 Secret Australian Business
0 Sundowner seat positioning
Last Post: Sportyman13
0 gerotor pump details
0 Zippers 1250 kit
0 Battery
0 Gas tank rust!
Last Post: Piemonte
0 new from socal
0 Craiglist finds
0 ISO parts for my 1986 build
Last Post: Peteroo
Old 28th August 2018
lynnx lynnx is offline
lynnx has a brilliant futurelynnx has a brilliant futurelynnx has a brilliant futurelynnx has a brilliant futurelynnx has a brilliant futurelynnx has a brilliant futurelynnx has a brilliant futurelynnx has a brilliant futurelynnx has a brilliant futurelynnx has a brilliant futurelynnx has a brilliant future
Default 1960 XLCH in the UK
Hi All,
I decided to combine my love of classic bikes with a penchant for customs.
So I bought a 1960 XLCH as its the same age as I am.
It has the looks I wanted, completely non standard of course, and needs a complete "recover".
Although an engineer by trade this engine is unlike anything else I,ve worked on and the manual is a must lol.
To that end I,ve started this thread in the hopes that the more experienced out there will bestow thy wisdom upon me.
I,d like to attach a "start" image but this site won,t let me - YET, I hope.
Its already in a million bits and I have questions.
But, lets see what response I get before I go wild!
Lynnx
as an owner of a 1960 XLCH,you have my attention.
Sprtstr1200s's Avatar
Sprtstr1200s Sprtstr1200s is offline
Sportster/Buell Model: Sportster XL1200s
Sprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond repute
I hope to see photos of the old girl. Good Luck.
Old 29th August 2018
Well, the FIRST question would be - why does my little box bottom right say I MAY NOT post attachments? and I have no "attachment management" button (see FAQ) and I,ve been in the POST REPLY.
Its like you don,t trust me or something (snuffle snuffle)
DirtyHarry68's Avatar
DirtyHarry68 DirtyHarry68 is offline
Sportster/Buell Model: 1968
DirtyHarry68 has disabled reputation
You have to make a certain number of posts before you can upload pictures, not sure how many but it’s only 5 or 10.
Where in the UK are you? I have a ‘68 which I imported a few years ago and have slowly been getting roadworthy. Ask if you need any parts as I’ve got quite a collection now!
Ah hah.
Best I get typing then.
I,m down the SW and thanks for the offer of parts.
I too am building a collection , but mainly by double ordering parts from J and P lol
(Check packet quantity folks)
Anyone need shifter fork rollers ?
So, before I close for the night, here's the starter question.
My XLCH cam gear cover has Torrington 3 x bh177 and 1 b118 needle rollers in instead of the (manual) stated bronze bushes.
It has nice little bronze thrust washers in between the cams and the rollers and nothing seems to be the worse for it.
Is this recognised mod? or just a bodge? The casing is the correct pt no and has a casting plate '59 so should be correct
Saves on reaming I guess.
Gearbox is out already then. Have you found the technical stickies? The hardest stumbling block I’ve come across is the many, many small variations in parts which in some cases make a big difference. And who knows whether what came out of it in the first place was original? All good fun of course.
that's a recognized mod by hot rodders to reduce friction.similar to the ball bearings used in KR/XLR motors.result is noisier valve train without the bronze bushings.
Old 30th August 2018
Back again.
So is it worth keeping in or should I replace them with bushes?
The frame has some extra bracing too, quite well done and that will be staying.
This bike had a hard time I feel … it also has an external oil filter mod and an oil cooler nailed on the side !
