Last Post: fafcpa
Last Post: Larry May
0 Getting Hammered
Last Post: Bryan83taco
0 Sportster kick stand
Last Post: ldurmon
0 Sleeve cylinders?
0 Sportster Cobra seat
0 Rain pants
Last Post: Rhode Warrior
0 Which Battery?
0 lengthen master cylinder
Last Post: kobra50
3 Shaky Dave Recovery
Last Post: ezmerf
0 cam lobes
Last Post: spamer80
0 Glyptal?
Last Post: Coz
nvlarry (65), Harby (65), gregor (62), Rainman (62), Dubfire (59), flathead45 (55), Shu (49), matt1971 (49), dgarber12771 (49), grino1200C (41), adamsmd127 (40), ws6envy (36), doomedcobra
Old 8th December 2019
Sportster/Buell Year: 1969
RicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of light
Nitro57xl, excellent talking point many times rocker arm bushings are overlooked.
Old 2 Weeks Ago
http://www.truettandosborn.com/Oilho...zingmethod.htm
The above link is for lowering oil return in engines with up to 4 and 5/8 stroke. My interpretation is that there is another method to do it for 4 and 5/8 stroke and longer. Please help me out what other method is there?
http://www.truettandosborn.com/Instr...clearance1.jpg Fine print at bottom has a no weld/braze method where a piece of tubing is inserted. Anyone here have any experience with this?
Old 2 Weeks Ago
T. Clark's Avatar
T. Clark T. Clark is offline
Sportster/Buell Model: XLS
T. Clark has much to be proud ofT. Clark has much to be proud ofT. Clark has much to be proud ofT. Clark has much to be proud ofT. Clark has much to be proud ofT. Clark has much to be proud ofT. Clark has much to be proud ofT. Clark has much to be proud ofT. Clark has much to be proud ofT. Clark has much to be proud ofT. Clark has much to be proud of
Probably the measurements they give will work on strokes up to 4 5/8", any longer and the oil return will probably have to be lowered even further. When I had T&O build up a 4 5/8" crank for me I also sent them my barrels. They lowered the holes, bored and fitted stroker pistons for me. Problem solved. Life is complicated enough without looking for trouble. If I was doing it again I would go for a 4 1/2" stroke and mild cams for a street motor. Motor has now done more than 16000 miles with no problems although it does love oil, apparently a common feature of stroker iron heads. Oil is cheap and regular top ups with fresh oil must be good for the motor!
Old 2 Weeks Ago
Scott Scott is offline
Sportster/Buell Year: 1981
Other Motorcycle Year: 2002
I may have posted this photo before - apologies if so. My shop built cylinders don't have drain holes for the heads. Here is the fitting that the front head will drain into. I'm thinking of using a "T" fitting and draining both front and rear heads into the same spot. I have a few other spots I'm considering, and have gotten some good advice on here.
Old 2 Weeks Ago
Did you send T&O your engine cases as well? When lowering the oil return in the cylinders a corresponding hole has to be drilled into the cases. On an Ironhead thats' 4 holes. As well as notching the barrels and engine cases for the rods. Anything less than 4.5 inch stroke doesn't require all that but then once it's been done it's done.
Old 2 Weeks Ago
T. Clark's Avatar
No, I notched the cases myself. It is not hard, just takes time and T&O have clear instructions on how to do this. S&S may also have instructions too. No need to re-align holes in crank cases, the hole into the cylinder wall is lowered but connects to the original holes that go into the barrel. I understand your issue if your cylinders do not have drain holes. I would suggest contacting T&O for advice. They are very helpful and know what they are doing, been building iron head strokers forever. I am sure they could do any required machining to get it all ready to go together. I sent my parts all the way from Australia for them to work on, don't regret it one bit. Seems like external drains may be the best option for you.
Old 2 Weeks Ago
mrmom9r's Avatar
mrmom9r mrmom9r is offline
The condition of the rocker bushings aren't a big concern once you realize that there is
an oil hole in the exh. rocker spewing oil at a pretty good rate.
I have built or seen built just about every combination of oil drain .
Real dragrace engines don't drain the oil at all because they don't pump any up there.
Nothing about oil drains is as important as piston clearance on a stroker.
No amount of oil will save a piston with inadequate clearance.
On a street bike I consider it as nothing but an appearance issue, if you want
to look Hi-Po lots of oil lines running everywhere sure looks impressive to the
uninformed.
Old 2 Weeks Ago
uninformed.
Speaking of piston clearance what do you recommend I set those forged pistons up at? .004?
I believe I have been a victim of setting up to tight in the past on my 93 inch Shovelhead. The crown of the piston separated from the skirt. Crown stuck at top of cylinder while skirt still attached to rod continued to travel up and down.
Old 2 Weeks Ago
I bought a set of used J-E forged pistons (new ones are NLA). The seller stressed nothing less than .004” clearance because they were forged. I visited my machinist friend with my cylinders and new (to me) pistons. I hesitantly mentioned the seller’s clearance recommendation, not wanting to imply my friend didn’t know what he was doing. In fact, he had already determined the pistons were forged because of their weight and had already planned on .004” clearance. I didn’t even need to say anything.
Old 2 Weeks Ago
This is what S&S shows for their forged line.
.0035" to .004" .0045" to .0055"
Tight fit .0035" to .004" loose fit .0045" to .0055"
Adding that loose fit will shorten life of pistons and rings with caution that tight fit requires significant adherence to proper break in procedure.
