Last Post: fafcpa
Last Post: Larry May
0 Getting Hammered
Last Post: Bryan83taco
0 Sportster kick stand
Last Post: ldurmon
0 Sleeve cylinders?
0 Sportster Cobra seat
0 Rain pants
Last Post: Rhode Warrior
0 Which Battery?
0 lengthen master cylinder
Last Post: kobra50
3 Shaky Dave Recovery
Last Post: ezmerf
0 cam lobes
Last Post: spamer80
0 Glyptal?
Last Post: Coz
nvlarry (65), Harby (65), gregor (62), Rainman (62), Dubfire (59), flathead45 (55), Shu (49), matt1971 (49), dgarber12771 (49), grino1200C (41), adamsmd127 (40), ws6envy (36), doomedcobra
Old 3 Weeks Ago
Tim The Grim's Avatar
Sportster/Buell Model #2: KHK
Sportster/Buell Year #2: 1954
Other Motorcycle Year: 96
These are the folks who did my KHK cams back in ‘80. They don’t list Sportster grinds on the website but they still have the capability.
http://www.webcamshafts.com/
I scrounged up the 2” aluminum bar and set it on the lathe with Dr. Dick’s drawing today. Hoping to do it Thursday.
Old 3 Weeks Ago
Sportster/Buell Year: 1969
RicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of light
Thank you. I'll see what they quote. I'll also pm you my info.
Old 3 Weeks Ago
Originally Posted by Ferrous Head View Post
If it's only at the edge of the lobe this may not be a problem.
The lifters should run on the middle of the cam lobe, not near the edge. With second hand cams you can often see just exactly where the lifter is running.
Having a hard surface layer mans if the cams are dropped onto a hard surface you can "chip" the surface on the side of the cam. If the chip isn't too big it may not be a problem.
keep a careful eye out for shiny metal when you do your oil change.
Unfortunately this blemish is right smack in the roller path. On the SIFTON Titan lobes they are very square, on #4 the blemish is right at the corner in the roller path. I'm still researching for repair. Running it as is will not give me any comfort.
Old 2 Weeks Ago
I shipped the new to me used SIFTON Titan cams off to Web Camshafts yesterday. They appear to be the company for restoration of antique cams. I'm hoping they can save mine.
Old 2 Weeks Ago
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
as you proceed through the repair process, can you share what expenses you encounter? I have a few sets of cams with one lobe with some damage that I may as well repair if it is cost prohibitive.
thanks
Old 2 Weeks Ago
thanks
I sure can. As of right now I have $373.00 in a set of SIFTON Titan cams advertised by Ebay seller as nice and ready to run. They are not. Web Camshafts will call me when they have looked them over to discuss best plan of action. I'll update here.
I recently discovered XLforum on Facebook and I can put pictures there.
Old 2 Weeks Ago
doodah man's Avatar
thanks
Hi mike, curious, on your different cam sets, is it the same cam number between sets with damage or different ones?
Old 2 Weeks Ago
No its not.
Couldnt be that simple Doodah, were you looking for a vulnerable culprit??
Perhaps a common failure on most #2's?? or 4's?? They range in 1 thru 4. Mostly collateral from roller failures for one reason or another.
I have 10-12 sets Ive come across over the years and just have not attemted any repairs just yet. They have always been on the"one of these days I'll have to send these to Black Widow or back to Mr. L's", shelf.
Old 2 Weeks Ago
doodah man's Avatar
Right on, yep, just curious of one particular cam or another was prone to fail. I thought I had a vague recollection of dr dick saying something about a specific cam being problematic, but don’t remember now where I read that, or if it’s maybe even a false memory. I have two old sets of p cams in my dungeon that have a crack in the surface, but like you said, it was due to the mating tappet’s roller.
Old 2 Weeks Ago
Happy to be of assistance. 😊
