0 Secret Australian Business
0 Chain Problems-'90XLH
Last Post: Four Speed
0 my sunday driver...
0 Colorado Trike
0 Newbie seeks smoother ride
Last Post: Jerry P
0 It's stalkie's Birthday!
Last Post: canoli
0 Tragic MC Museum Fire
Last Post: sprink
0 1275 or 88 or 90 CID for 4-Speed
0 Lifespan for Shorai LiFePO4 Battery?
0 Clutch spring question
Last Post: JonesL
0 Boardtracker Project
Last Post: JonesL
0 looking for controls
Last Post: schaffersshovel
0 Flat Tracker Conversion
Last Post: 45Brit
0 Removing Rear Shock
Last Post: 45Brit
0 Pistol Braces
0 gas tank Quick connect leaking
Last Post: packdog
Last Post: 109Countries
0 Range With EFI 4.5 Gal Tank
jurneyman (79), AdO650 (65), xlsport (63), darth (60), mcsmokinp (56), stalkie (56), unleashed66 (55), 66xlch (55), lownslow (49), hrg (47), Ironduke (45)
Old 11th January 2020
SHAKY DAVE's Avatar
SHAKY DAVE SHAKY DAVE is offline
Sportster/Buell Model: XLX
Sportster/Buell Year: 83
Sportster/Buell Year #2: xlh
SHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to all
hope you orderd a James top end set.comes with everything your gonna need
Old 12th January 2020
Tim The Grim's Avatar
MetalWorkingXLFan
Sportster/Buell Model #2: KHK
Sportster/Buell Year #2: 1954
Other Motorcycle Year: 97
When you’re putting your heads back on, make sure you align them with the intake manifold before you tighten your head bolts.
I ran Wiseco hi comp pistons and the thin copper gaskets on a ‘76 for 10+ years with no issues.
My 1st two H-Ds were flatheads. The KHK used no head gasket at all, just a coat of aluminum paint on the mating surfaces. The trike used a plain copper gasket and we would use the aluminum paint on both sides of that gasket.
Not being one to change my spots, I used the same type paint on the plain copper XL head gaskets too and never had any problems.
Just don’t use any gooey stuff that might clog an oil return.
11B40 11B40 is offline
While you are in the head, you might take out the valves and inspect the seats, if a bit rough you can wipe on some lapping compound and hand lap them to renew the seats. When they are right, they will hold gasoline and not pass any through the valve seats. It is really easy to incorrectly adjust the valves and burn a valve/seat if you do it wrong. It is only as good as the last guy who worked on it. Pity to scrape everything clean and leave a leaky valve.
Ethal iron Ethal iron is offline
Ethal iron is an unknown quantity at this point
Tim the grim,, I did see a video on that so ill make sure that happens. That would explain the problems I had with my manifold.11840,, I also have a friend that's going to walk me to doing a valve job. You're right,it would be a shame to go through all this and not make sure it's perfect.
