12th January 2020
Posts: 179 Sportster/Buell Model: xlh Sportster/Buell Year: 1981 Other Motorcycle Model: Suzuki GS850GL Other Motorcycle Year: 1982
How much is too much?
I've been chasing an engine knock, which I suspect is coming from the front cylinder. I pulled the motor and removed the top end. I don't feel any up/down of the rod, but I can wiggle the rod side to side quite a bit. How much movement is too much?
Btw, this is what the piston looks like:
12th January 2020
Posts: 11,032 Sportster/Buell Model: XLCH Sportster/Buell Year: 1975
There is no side shake specification in the fsm for ‘77 and up, only up and down on the crank pin to rod fit. Your pistons look like they might have been fit tight previously. Maybe the noise you are hearing is piston slap? Does the other piston look the same?
12th January 2020
I'm pretty sure what I've been hearing is piston slap. The rear piston looks perfect.
13th January 2020
What causes piston slap anyway?
13th January 2020
Posts: 4,404 Sportster/Buell Model: XLCH Sportster/Buell Year: 1974 Sportster/Buell Model #2: XLS Sportster/Buell Year #2: 1980
I would check cyl for egg shaping,check bore and piston size but I'm betting on bad egg shape cyl.
Murphy's Law :vvet:
13th January 2020
Posts: 277 Sportster/Buell Model: XLH1000 Sportster/Buell Year: 1977 Sportster/Buell Model #2: 2004 XLH1200Custom Other Motorcycle Model: 2007 FXDB Other Motorcycle Year: 2004
Only cure is cylinder boring and over sized pistons and rings. Best to bore both cylinders so they match.
13th January 2020
MetalWorkingXLFan
Posts: 559 Sportster/Buell Model: XL1200V Sportster/Buell Year: 2013 Sportster/Buell Model #2: KHK Sportster/Buell Year #2: 1954 Other Motorcycle Model: Valkyrie Other Motorcycle Year: 97
I would say you have a lean condition in your front cylinder, caused by an air leak, that causes just enough overheating so that the trailing surface of the front cylinder, where your air flow is minimal, gets hot enough to negate the oil splash and cause the galling that’ we see.
The piston is hotter because of the lean condition and over expands into the fit tolerance where everything is hotter.
Your not at a point of seizing up, but pretty damn close.
How’s your wrist pin fit? Piston slap has a sort of a ring to it rather than a plain knock.
Your rear cyl is ok without the leak. Running richer and staying cooler.
In the old days...if the top of the male rod moved more than 3/32 total, side to side, they recommend doing a crank pin and bearings. I ran a motor at that max for years without any problems.
I’ve seen parts like yours cleaned up, fits checked and go back in service.
It is farm equipment after all. 😛
13th January 2020
Posts: 14,284 Sportster/Buell Model: xlch Sportster/Buell Year: 1960
piston slap is from too much clearance between the piston and cylinder wall.
13th January 2020
You can't clean up piston slap, you might be able to clean the bore if it's not too fuxored. It certainly needs a new piston in the front hole.
If there is anything in the bore that you can catch a fingernail on it is probably past it's "use by date". Cool thing is you don't have to bore BOTH cylinders if it comes to that.
The pistons are all pretty much the same weight and the motor doesn't care if one hole is bigger. I would not bore a good cylinder just to make it match, you can't get OEM cylinders any more and sleeving is not an option in my book.
13th January 2020
I took the cylinders to my favorite machinist today. There's no scratches that can be felt on either cylinder, and they measure up fine. He's going to hone them, and I've ordered a set of std pistons and rings. He also suggested the front hole had a lean condition, causing this issue.
