0 Dodgy Group Members
Last Post: Bryan1976
0 1969 XLCH Shifter Issues
0 Paid Hammer, Parts Are In The Mail
0 St. Andrew(s), save my tranny!
Last Post: mastiffhound
0 1275 cams
0 Newbie seeks smoother ride
Last Post: TowPro
0 Boots
0 front brake line help - 1980
Last Post: T. Clark
0 90XLH Hugger Forward Control Help/Install Questions.
Last Post: rickxx
0 1970 sportster overload
0 Pinion shaft roller bearing plug fit
0 THE Trainspotting Thread
Last Post: 83XLX
0 Identity crisis
Last Post: maltesefalcon
0 Mikuni VM38-9 on Kickstart Bike?
Last Post: 45Brit
0 Tires & Shocks Needed: '90XLH 883
Last Post: Rollbar
0 front end conversion
0 Has anyone replaced rubber floorboard dampers?
Last Post: Jerry P
0 Rear fender spacers?
0 Secret Australian Business
Last Post: fernf5
0 Oil Cooler installation on an early Ironhead
IronHead83, AMATRAVELER (59), ZYBAN (57), tom_ski (56), mid30 (55), im_justin_sane (53), DOZER (51), acman145acp (51), espacef1fan (36), fernandopn (36)
Old 13th January 2020
Zari Zari is offline
Sportster/Buell Model: Xlh 1000
Sportster/Buell Year: 1982
Zari is a splendid one to beholdZari is a splendid one to beholdZari is a splendid one to beholdZari is a splendid one to beholdZari is a splendid one to beholdZari is a splendid one to beholdZari is a splendid one to beholdZari is a splendid one to beholdZari is a splendid one to beholdZari is a splendid one to beholdZari is a splendid one to behold
Default pressure gage
which kind of gage can install on the head to measure the pressure
Do installation as in the appropriate image????
https://photos.google.com/album/AF1QipO0KspqtN_JbQPp8PkxFpylQbcVx6z1ZsGTo8Wk/photo/AF1QipMeouHEDA2SE0g92Kya229Zst1O8T3afs7l6A-e[/IMG]
Hippysmack's Avatar
Your link didn't work for me.
It asked me to sign into google which I don't do.
But we have information in the XLFs Sportsterpedia on installing a gauge at this link:
http://sportsterpedia.com/doku.php/techtalk:refil15
This drawing should be accurate for installing an oil gauge.
An oil pressure gauge is useless on an Ironhead.
You cant see a gauge at night and there are no gauges made that will accurately display 3psi that you will see at a hot idle and not blow up with 80psi on a cold start. (Plus the vibration issue)
Keep the light it is the right choice.
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
If it really needed one the factory would have installed one.
I would not go that far as the factory did not install oil coolers or filters on some models.
And the Stealer will gladly sell you an acc'y gauge, and take your $ with a smile.
Davo_137's Avatar
Davo_137 Davo_137 is offline
At what pressure does the light come on?
I think it is 3psi
Old 14th January 2020
Hippysmack's Avatar
Rick's right.
Hot idle pressure is suppose to be 3-7psi.
The oil switch sends signal to the light for it to come on.
So the light coming on depends on the condition of the switch.
It's spring loaded so sometimes it'll vary.
The check valve spring is what makes the pressure to turn the light off.
Hippysmack's Avatar
Yes, the check valve provides the pocket of pressure that operates the switch.
