0 Sundowner seat positioning
Last Post: 4schizzle
5 Tire Pressure?
0 75 IH Oil leaking into starter from primary side/ bendix
Last Post: BelleBanger
0 Any experience with REBUILT title?
0 Boardtracker Project
0 Smoke and top end job
0 v twin Crankshaft Bushing Plate Pilot and Reamer
Last Post: thecarfarmer
Last Post: psycho69
0 Clearance between clutch faces 1974 transmission
0 Pinion shaft roller bearing plug fit
Last Post: Jaime1840
Last Post: rider61
0 Secret Australian Business
0 gerotor pump details
0 Zippers 1250 kit
0 Battery
0 Gas tank rust!
Last Post: Piemonte
0 new from socal
0 Craiglist finds
Old 13th January 2020
Sportster/Buell Year: 1969
RicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud of
Default math problem, piston rings
I need to order piston rings for my 900 with a 3 inch bore which is now .040 over. I figured I could find rings that were +.040 but Dennis Kirk sells them like 3.197, 3.207, 3.217, etc. I seem to have missed that math class. Which set is it and how do you compute it?
forqueue forqueue is offline
Sportster/Buell Year: 1976
forqueue has disabled reputation
No idea. But Bill has what you need.
.040"
HD 22360-57A
https://www.billscustomcycles.com/sportster/rings
.040"
HD 22360-57A
OH NO! Not a cast oil ring. LOL
Sorry I'm looking for 3 piece oil ring. I just need to order the correct size.
Those numbers are the oversize added to the standard bore size. So standard bore = 3-3/16 or 3.1875.
3.1875 + .020 = 3.2075
3.1875 + .040 = 3.2275
Looks like they don't include the 5 in the part number
900 standard bore is 3.0, 1000 is 3-3/16 correct?
900 standard ring would be 3.005
Yes, your right. I forgot you're working on a 900. Standard bore 3.000
Sportster/Buell Year: 1971
Sportster/Buell Model #2: xlh
Other Motorcycle Year: 2011
A quick look over at Hastings revealed they only have STD rings for the 900. Seems odd they only have STD for the 900, while they have oversized for 1000 motors.
Typically they are good at responding to e-mails. When I had questions, I had responses same day or next day at the latest.
If you strike out elsewhere, I'd suggest an e-mail to --> info@hastingsmfg.com <-- . They might provide a recommendation (or not).
hastings 900 cast rings w/3 piece oil ring +.040 VTwin #11-0104 "in stock"
std thru .070 in .010 steps
please check link. It's some kind of shower for a tub.
Link this 900cc-piston-ring-set-040-oversize
