Last Post: fafcpa
Last Post: Larry May
0 Getting Hammered
Last Post: Bryan83taco
0 Sportster kick stand
Last Post: ldurmon
0 Sleeve cylinders?
0 Sportster Cobra seat
0 Rain pants
Last Post: Rhode Warrior
0 Which Battery?
0 lengthen master cylinder
Last Post: kobra50
3 Shaky Dave Recovery
Last Post: ezmerf
0 cam lobes
Last Post: spamer80
0 Glyptal?
Last Post: Coz
nvlarry (65), Harby (65), gregor (62), Rainman (62), Dubfire (59), flathead45 (55), Shu (49), matt1971 (49), dgarber12771 (49), grino1200C (41), adamsmd127 (40), ws6envy (36), doomedcobra
Sportster/Buell Year: 1969
RicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of light
retail price $84.51 cha ching. Supply and demand...
Originally Posted by ryder rick View Post
Tedd cycle, have to be a dealer to make purchase. ????
doodah man's Avatar
Have you checked BMI karts?
https://www.bmikarts.com/Set-of-Two-...71_p_6997.html
Ten bucks cha ching!!!
Unfortunately those rings are a direct replacement for the stock factory rings with a one piece cast iron oil ring.
The picture shows a 3 piece ring, I wondered about that...
One piece oil rings break way too easy.... If I have a choice, I am going the other direction even if they are marked up with a crazy price
You're right the picture does show 3 piece. I went ahead and ordered, I'll let you know what I get. lol
The shipping might be more than the rings, so not much to loose.
But silly me, I'd run the old rings, unless they got borked.
Often the rings will out last the pistons. If there is nothing wrong with the cylinders the rings are good. If the rings are worn out the cylinders are more than likely fuxored.
I won't replace tested good parts as it introduces potential failures, causes more wear (break-in), and wastes money. And I'm a cheap bastard, even if I am spending your money. I'll spend that money for you somewhere else that makes a real difference.
I see guys dump thousands of dollars into a motor but have 4 year old tires and junk shocks or still run points ignition.
randy3934's Avatar
what's wrong with points?
Nothing, but I will beat you with Electronics!
I have new S&S 4 and 5/8 stroker pistons and no rings.
