Last Post: fafcpa
Last Post: Larry May
0 Getting Hammered
Last Post: Bryan83taco
0 Sportster kick stand
Last Post: ldurmon
0 Sleeve cylinders?
0 Sportster Cobra seat
0 Rain pants
Last Post: Rhode Warrior
0 Which Battery?
0 lengthen master cylinder
Last Post: kobra50
3 Shaky Dave Recovery
Last Post: ezmerf
0 cam lobes
Last Post: spamer80
0 Glyptal?
Last Post: Coz
nvlarry (65), Harby (65), gregor (62), Rainman (62), Dubfire (59), flathead45 (55), Shu (49), matt1971 (49), dgarber12771 (49), grino1200C (41), adamsmd127 (40), ws6envy (36), doomedcobra
  #31
This?
http://xlforum.net/forums/showpost.p...9&postcount=26
I'm no Luddite; I just hate the march of technology.
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Pehaps that is the one, I seem to remember a bit more detail. It would not surprise me if he had made a few attempts at getting the point of that conversation across. Either way this link gets the point across. Different scenerios need different applications to arrive at the same point.
Sportster/Buell Year: 1969
RicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of light
Originally Posted by thefrenchowl View Post
Ric,
With maths like yours on post #5:
""900 standard bore is 3.0, 900 standard ring would be 3.005""
I wouldn't want to buy any engine that's been near you!!!!!!!!!!!!!!
Patrick
Well Patrick I'm so upset. How about you educate me. A 900 HD Sportster has a standard bore of 3 inches. Tell me about rings, what do you know? Please tell me how a 3.00 ring in a 3.00 bore with the proper end gap would seal.
Rings are not measured outside the bore. They are machined at a significantly larger diameter then cut so they have tension on the bore.
Many buy oversized rings and hand fit down, so it is easier to butt the ring ends.
Production rings are almost always on the small side (large gap) to prevent butting.
A small Ring end gap is not critical unless you are racing in a limited class against someone with a tighter gap, (splitting hairs) and can't run a total seal ring because of rules. Not sure a total seal ring works well on the street or in a dirty motor like an Ironhead.
Rings seal because compression pushes them down and pressure gets behind the ring and forces it out against the cylinder. This is why many race motor pistons are "gas ported". However I don't believe that works on the street.
Nailed it.
thefrenchowl's Avatar
Sportster/Buell Model: KHK
Sportster/Buell Year: 1954
Sportster/Buell Year #2: 1978
Other Motorcycle Model: XLRTT
thefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant future
What Rick said, Ric…
You cannot measure a ring outside the bore, ie a 3.005 diam ring could not possibly seal a 3" bore.
Or look at it another way: machine on a lathe a 3"005 ring, then cut the gap: When you fit it in a 3" cylinder, maybe three points on the ring will actually touch the cylinder… ie NO SEAL despite the spring effect…
A 3" ring is a bigger diameter ring, then cut, then compressed, then machined round at 3", then gapped… that's the only way you'll get more than 3 points touching the bore.
Same logic when you want to redo seriously your drum brakes linings on a lathe: insert shims between shoes and cam, then skim linings on lathe to your drum ID then remove shims and as soon as you touch the lever, all the points of your linings will touch the drum = maximum brake surface instantly…
Patrick
Flat Head Forever
I'm not on here to argue with folks. I ask a simple question. It's been answered thank you.
mrmom9r's Avatar
mrmom9r mrmom9r is offline
I'm the one who sold you the pistons . The information you seek is:
Hastings 6457-040 cast iron
Hastings 2C 6457-040 moly faced cast iron
Thank you. The pistons and new cylinders with oil returns lowered are in local shop getting fitted. I ordered rings from BMI Karts they will arrive today. Not sure of brand or even if they have 3 piece oil ring. They were cheap so if there not Hastings rings they will go on the shelf and I'll order the ones you have identified.
All is well Ric, sounds like you know what you're doin'...
Patrick
