0 Carburetor opinions
0 Hello from Az
Last Post: ggobe
Last Post: Bryan1976
0 rotating engine by hand
0 Clean my Clock
0 1960 XLCH in the UK
0 MAP Request-TC88A
Last Post: 1Scooter
0 IH sidecar road racer
Last Post: Yakcm2
0 Rico Lutsey aka Rico 05R
0 Change jets without removing carb?
0 Hello from the Northeast US.
Last Post: 84cj
Last Post: A Seabee
Last Post: Lone Rider
0 Next Project - 1275cc Engine Build - Which Year & Why...?
0 crank case breather
0 SERIOUS 1275 engine issues!! PLEASE HELP!!
Last Post: Boil1337
0 My new LED headlight
0 Harley Davidson Sportster: 60 years by Allan Girdler
Last Post: Boil1337
0 New member
Last Post: jharback
0 Fatster Project
Last Post: Tonyb65
irvingjr (71), 909XR (62), Ghost_FL (60), mark R (59), TWISTED (46), spade (44), Drivethis29 (39), dodgetrucken (34)
ignition, kill switch, pinging, timing
Old 29th August 2019
T_worth T_worth is offline
Sportster/Buell Model: Xlh 1200
Sportster/Buell Year: 96
T_worth has a spectacular aura aboutT_worth has a spectacular aura aboutT_worth has a spectacular aura aboutT_worth has a spectacular aura aboutT_worth has a spectacular aura aboutT_worth has a spectacular aura aboutT_worth has a spectacular aura aboutT_worth has a spectacular aura aboutT_worth has a spectacular aura about
Default ignition AFTER kill switch engaged.
I have a 97 xl1200 sport with a s&s super E carb (with thunderjet installed) and paughco upsweep pipes. I am running NGK DCPR7E plugs.
I'm in the process of jetting my carb still, but I think I'm pretty damn close. The bike idles and runs well. I have two timing concerns with the bike. I'm getting a pinging/knocking sound at low throttle and sometimes when I hit the kill switch while in Neutral, my engine will roll over a few times.
Would both issues be from my timing being off?
I read about normal summer riding heat, heavy loads, higher octane fuel, etc but would like to know if its related to my timing being off.
Have you set the timing according to the manual?
Don't lug the engine - keep the revs up above 2500-3000 when operating the bike...
Here's the Sportsterpedia section on setting the timing - Note the small movement that makes BIG changes in the timing...
http://sportsterpedia.com/doku.php/t...dels_thru_2003
Have you checked the plugs for burning lean? Have you checked for intake air leaks with a propane torch?
Old 30th August 2019
Davo_137's Avatar
Davo_137 Davo_137 is online now
Sounds like it’s got way too much advance.
Old 2nd September 2019
I got a timing gun. The 2 timing marks appeared slightly to the right side of the center inspection hole. Is the right side “advance” and left side “retarded”?
After I remove the rivets from the timing cover, what size screws should I use to reattach cover?
Davo_137's Avatar
I don’t know how to time your engine sorry, you might have to buy or download a workshop manual.
