0 Carburetor opinions
0 Hello from Az
Last Post: ggobe
Last Post: Bryan1976
0 rotating engine by hand
0 Clean my Clock
0 1960 XLCH in the UK
0 MAP Request-TC88A
Last Post: 1Scooter
0 IH sidecar road racer
Last Post: Yakcm2
0 Rico Lutsey aka Rico 05R
0 Change jets without removing carb?
0 Hello from the Northeast US.
Last Post: 84cj
Last Post: A Seabee
Last Post: Lone Rider
0 Next Project - 1275cc Engine Build - Which Year & Why...?
0 crank case breather
0 SERIOUS 1275 engine issues!! PLEASE HELP!!
Last Post: Boil1337
0 My new LED headlight
0 Harley Davidson Sportster: 60 years by Allan Girdler
Last Post: Boil1337
0 New member
Last Post: jharback
0 Fatster Project
Last Post: Tonyb65
irvingjr (71), 909XR (62), Ghost_FL (60), mark R (59), TWISTED (46), spade (44), Drivethis29 (39), dodgetrucken (34)
painterdude923's Avatar
painterdude923 painterdude923 is offline
painterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to behold
Default Starter ring gear
I had a few teeth broken off of the ring gear last year, so while I had the transmission out getting redone I replaced the ring gear. What a pita that was! Been riding for a couple of months with my new 1275BFH Hammer setup, then started having starter issues again! Then it wouldn't engage at all! I took the primary off and holy sh@t!! Ring gear is wasted!! So much ground off ,broken teeth, what a mess! Ordered a new clutch basket and ring gear. Before I put it all back together, what is going on with my starter/ring gear issues? Don't want this to happen again!
Did you check the solenoid activation? The solenoid is supposed to move the pinion gear into mesh with the ring gear before (or as) the starter motor begins to run... Maybe your solenoid is sluggish getting that pinion gear engaged...
It's an All Balls racing starter. High torque!
Have any pictures to help assess the issue?
Yes. Just have to figure out how to get them posted on here
Been trying to get a picture on here
Read the FAQ/HowTo threads (includes several how-to post pictures) here:
http://xlforum.net/forums/forumdisplay.php?f=16
But PLEASE DON'T USE PHOTOBUCKET as a hosting site...
