0 Carburetor opinions
0 Hello from Az
Last Post: ggobe
Last Post: Bryan1976
0 rotating engine by hand
0 Clean my Clock
0 1960 XLCH in the UK
0 MAP Request-TC88A
Last Post: 1Scooter
0 IH sidecar road racer
Last Post: Yakcm2
0 Rico Lutsey aka Rico 05R
0 Change jets without removing carb?
0 Hello from the Northeast US.
Last Post: 84cj
Last Post: A Seabee
Last Post: Lone Rider
0 Next Project - 1275cc Engine Build - Which Year & Why...?
0 crank case breather
0 SERIOUS 1275 engine issues!! PLEASE HELP!!
Last Post: Boil1337
0 My new LED headlight
0 Harley Davidson Sportster: 60 years by Allan Girdler
Last Post: Boil1337
0 New member
Last Post: jharback
0 Fatster Project
Last Post: Tonyb65
irvingjr (71), 909XR (62), Ghost_FL (60), mark R (59), TWISTED (46), spade (44), Drivethis29 (39), dodgetrucken (34)
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
Start at the battery ground spot on the motor mount bolt. Clean it shiny.
Use the ohms scale of a multi meter. Touch the two leads together and make sure that it reads less than one ohm.
Clip one lead to the clean shiny metal then start checking around the frame with the other lead.
Sleepy Labeef rides again!
broknluck broknluck is offline
Sportster/Buell Model: 883
broknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud of
Im rewiring with new wires.Ground point is from bike frame.A hot jumper is used to power newly wired switches and buttons. Test light is used to determine there is a connection all was working as planned that not of issue... Now the only time test light will light is from neg/pos posts battery.Battery is 13 amps.Do not over think this No grounds of any kind is working on motorcycle works at all with any test light.
Maxeffort's Avatar
There is no connection from the negative terminal to the frame.
sportsterdoc's Avatar
Post 10 questions numbered to facilitate answers.
Davo_137's Avatar
Davo_137 Davo_137 is online now
battery is used to power test light with a small jumper cable as a hot led to test connections.
Ok a continuity test light? I thought you were talking about a standard test light haha.... never mind.
There is ground connections tried everywhere yet no/go.It is going against nature, I try using frame as ground its a no/go.Every thing works on other vehicles Nothing grounds.
Maxeffort's Avatar
Obviously not! Either you have ZERO understanding of electricity, OR you are just trolling us for entertainment.
[SIZE="5"]I try using frame as ground its a no/go.
How is the frame connected to the off-the-bike automotive battery?
Third request for answers to post 10 questions.
If the test light is functional and it fails to light, the circuit is open...most likely the negative path is not complete.
... I lost the ground point.I tried many other ground points in desperation I drove a metal stake with a wire to ground and poured water on the tires of the bike,nothing has worked...
Possibilities include:
A. This is a joke or troll or
B. Basic electrical knowledge does not include grounding a circuit to the battery.
C. The ground point on the bike is not making electrical contact to the battery ground.
Default What I Found.....
[SIZE="5"Remember the Test Light did work on every ground spot then stopped....So finally I tried a Multi Meter and got readings 5,8,10 amps.Yet strangely Test Light still will not pick up on it as it once did.It is fairly new 1 month old and prefer it for simple checks but it seems to be ailing and the cause of the ruckus.I can not trust anything new,Dont buy 2 to check the other. [/SIZE]
