0 Carburetor opinions
0 Hello from Az
Last Post: ggobe
Last Post: Bryan1976
0 rotating engine by hand
0 Clean my Clock
0 1960 XLCH in the UK
0 MAP Request-TC88A
Last Post: 1Scooter
0 IH sidecar road racer
Last Post: Yakcm2
0 Rico Lutsey aka Rico 05R
0 Change jets without removing carb?
0 Hello from the Northeast US.
Last Post: 84cj
Last Post: A Seabee
Last Post: Lone Rider
0 Next Project - 1275cc Engine Build - Which Year & Why...?
0 crank case breather
0 SERIOUS 1275 engine issues!! PLEASE HELP!!
Last Post: Boil1337
0 My new LED headlight
0 Harley Davidson Sportster: 60 years by Allan Girdler
Last Post: Boil1337
0 New member
Last Post: jharback
0 Fatster Project
Last Post: Tonyb65
irvingjr (71), 909XR (62), Ghost_FL (60), mark R (59), TWISTED (46), spade (44), Drivethis29 (39), dodgetrucken (34)
Clevspeed's Avatar
Clevspeed Clevspeed is offline
Sportster/Buell Model: 2003 Sportster 883R/1200
Clevspeed has disabled reputation
Default Headlight
This stock headlight is gonna get me killed! What’s a good headlight to use?
Thanks Clevspeed!
883RS/1250
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
Thanks Clevspeed
The Wisamic LED is very popular. I have riding buds that have installed them and it’s a powerful headlight
https://www.amazon.com/Wisamic-5-3-5...s%2C141&sr=8-1
That headlight wouldn’t easily fit in my 1996, so I went with a 7” conversion. It’s a huge improvement
e
Sleepy Labeef rides again!
Glamazon Glamazon is offline
Sportster/Buell Model: xl883r
Sportster/Buell Year: 2014
I've been using xenon bulbs.
In the 70s I rode BSAs & Triumphs with 6 volt Lucas prince of darkness lights so I think HD lights aren't so bad!
Nibelungen's Avatar
Senior Master Bike Builder
same here
an expensive bulb the xenon one
yet cheaper than replace the headlight with a quality LED one
if the end justifies the means... then who does justify the end?
BKB's Avatar
BKB BKB is offline
+1 for the Wisamic.
mikeLI_77's Avatar
I have the daymaker and it works really well. I could not come close with any halogen or hid bulb although hid and some other aftermarket bulbs are better than stock. Although when I bought my daymaker they didn't have all of these copycats around. If so I probably would have tried the wisamic one and saved myself around $300. I also have a 7" daymaker which does put out more light than the 5 3/4" one but I went back to stock size because I broke 2 headlight buckets from the vibration from my solid mount. I may try one of those side mounted headlights so Incan get the 7" back on my bike some day.
2002 XL1200C (originally)
Dyno Sheet
96.21 HP/88.70 TQ
States I Have rode through
