0 Do not buy this oil!
0 WTS: Forward Controls 2004-13
0 New Harley CEO
0 Vulcan Mid Glide Triple Tree Conversion Set
Last Post: Dariusz
Last Post: Marsikus
0 New oil tank
0 Ironhead Exhaust Poll
0 random rattle
0 Bike wobble question
0 top end rebuild
0 XLCH 900 1969 Build Thread
Last Post: XL1275
0 Clutch blow up
0 Stock vs. Modified
0 Membership $20? am I missing something here?
14 Buell back in business?
Last Post: AZbiker
0 Fyi
Last Post: AZbiker
6 Hello Folks
0 One for the dad joke collection
Last Post: maltesefalcon
patc, Camera108 (67), pbudrovic (65), Rob Roy's Revenge (64), gene04 (63), guvnor (56), jrogers329 (50), ksoggs (45), dmurphy68 (43)
ignition, pensacola, spark plug
Old 16th May 2018
Titaniumrust Titaniumrust is offline
Sportster/Buell Model: 883L
Titaniumrust is an unknown quantity at this point
Default Engine turns but no spark at the plugs. 05 883L
I am not getting any spark at my plugs. The engine turns over, all the lights and signals work, I can even smell gas getting to the plugs.
Most likely the problem is me. I Changed a lot of stuff at once and being a idiot I just figured I could put it all back together without a problem. I replaced the handlebars with some baby apes. This required all new lengths of wiring. So instead i relocated most of the controls and only ran what I had to. The kill switch and start button are located on the exhaust side of the bike below the seat. The turn signals are wired and on the opposite side of the bike under the seat. I also have relocated the key switch to behind/under the seat like alot of people. I have replaced all the fuses i can find, put in new spark plugs, and new spark plug wires. I replaced the ignition module under the seat pan. The only thing that i have not replaced is the actual ignition coil. I think that is what it is called.....the actual thing the plug wires run into. I have gone over everything that i can think of. I am sure I have simply cut a wire or not hooked something back up correctly. Anyone have suggestions or a very simple wiring diagram that i can see. I would take something drawn in crayon if it will help me. I am in Pensacola, Fl and not having my bike running is killing me. any help is appreciated.
Old 16th May 2018
sportsterdoc's Avatar
Welcome to the forum.
Post one of this thread is a start: http://xlforum.net/forums/showthread.php?t=1869052
Old 16th May 2018
On an unmolested 2004-2006:
Gray wire from ignition fuse feeds stop/run, which then feeds white/black to start button.
Since starter functions, that should be OK
Does white wire with black stripe provide 12 VDC to coil?
If so, then does yellow/blue (rear) and blue/orange (front) connect coil primaries to ICM proper positions?
If so, is crank position sensor connected to ICM proper positions?
If the crank position sensor properly provides the signals to the ICM, and if the coil has power and is connected to the ICM, you should have spark.
Old 17th May 2018
Here's the Sportsterpedia section on how to Manually Trigger the Coil / Spark Plugs:
http://sportsterpedia.com/doku.php/t..._testing_spark
2 Relax
FREE XLForum Organized Tech Info - Check Out The Sportsterpedia
Old 17th May 2018
Default No power to the coil.....
---White wire with black stripe does not provide any power to the coil.
Old 17th May 2018
Follow the voltage trail to where it stops.
If you have power to the ignition switch, continuity is missing from there to the coil.
Does your stop/run (in my world a "kill switch" grounds the - side of the coil primary, same effect as points or ignition module not opening) provide power to starter button, as does the stock wiring?
If so, does it also provide power to the coil?
Old 25th May 2018
Followed the white wire with black stripe back to the ignition module under the seat. There is a brown wire with gray stripe that provides the 12v to the module but does there is no power coming out of it. It is a new one. I replaced it first thinking it was the problem. What are the odds of me actually getting another bad one? The one I bought new is a Dynatek DSPT. Rev limit set to 6250 and the advanced knob set to 38A. These were the settings I found online that said they were the best for my model. Was out of town for work and just now got back too it
Old 25th May 2018
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
What procedure are you using to test for spark?
On these crank trigger bikes, you won't get spark without compression. So it's not like the old days when you could pull the plugs and put the boot on them and lay them against a head bolt and crank the motor over while watching for spark. You won't get spark that way. You have to put some other plugs back into the spark plug holes, so that you have compression.
If that's not what's going on, do you have the original module still? If so, swap it on and see what happens.
Click Here to Contact Me
Old 26th May 2018
That is exactly what I did to check the first time but then read a post that told me about the compression. After trying to fire it up you can actually smell the fuel. I put the original module back on again this morning and had the same problem. Not getting any power to the wire that runs to the coil. I'm assuming that I can't just run another 12v source to it.
Old 26th May 2018
Why not?
It is simply switched 12 vdc power.
The wires from coil primaries to ICM need to be in place and the CPK needs to feed positional info to ICM for the primaries to function, but jumpering the 12 vdc to the coil primary + should let you know if that is the only issue.
ICM position numbers – purpose – wire color
1 run/stop w/bk (same as feeds coil primary)
2 battery bn/gy
3 +5 sensor power r/w
4 sensor ground bk/w
5 module ground bk
6 coil, front be/o
7 coil, rear y/be
8 crank position sensor + r
9 crank position sensor - bk
10 vehicle speed sensor w/gn
11 MAP signal v/w
12 data link lgn/v
TSM/TSSM
1 battery bn/gy
2 ignition gy
3 serial data link lgn/v
4 security indicator
5 left turn output v
6 right turn output bn
7 right turn input w/bn
8 left turn input w/v
9 starter relay control tn/gn
10 ignition enable switch
11 alarm signal lgn/bn
12 ground bk
