0 Ironhead engine problem?
Last Post: gl90hog
0 North central Mass
0 NOS cases
Last Post: davixlrtt
Last Post: Akeemking
3 Wtb, Wts, Wtt, Wtg (Buells)
3 Wtb, Wts, Wtt, Wtg (XRs)
3 Wtb, Wts, Wtt, Wtg (EFIs)
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: DR DICK
Last Post: DR DICK
0 BEWARE Of SCAMMERS!
0 Showa 54000088 Shocks
Last Post: d10221
Last Post: JimVonBaden
0 1968 ex barn dweller thread
0 XR1000 black and orange pics?
0 my sunday driver...
0 XR1000 Pushrod Tube Leaks
Last Post: KRTTXRTT
excel50 (80), blazer95 (71), mycle1000, Barryn37 (60), QBALL (60), paulieb (59), cfranz (48), BMXATV (47), ravyn3 (42), Texas_Wild, hillpope (39)
Old 11th June 2021
79Harleydavidson 79Harleydavidson is offline
Sportster/Buell Model: Ironhead xlch
Sportster/Buell Year: 1979
79Harleydavidson is an unknown quantity at this point
Default Breather
Ok so Im unsure if this is a being over anal or if I need to look more. I run standard 20w50 Cam2 motor oil. I got the oil level good, and fired the bike up yesterday. I still have yet to do a beat run on it but ran it a few times around my neighborhood (big ol figure 8) just putted around and watched the breather. While driving it seemed to be running great. Nothing "puking" so to speak. As soon as I got in the driveway which mind you is a downhill, It sat idling and I watched with every puff just drops of oil come out. With that , should i just route a hose up the front forks so the vent still works and oil drains down? Should I be running a thicker oil as well? Ive typically ran 20-50 vs the 50 or 60 weight especially for spring and fall up here. if I pull the genny, can I see the reed valve and should I check if the oil drain hole is blocked up as well? Other than that the blue smoke on the rear cylinder cleared up and she ran like she did before my array of issues started this year. Thanks again for all the help guys.
Old 11th June 2021
BigMek's Avatar
BigMek BigMek is offline
Sportster/Buell Year: 1982
Are you using the upper or lower breather port? If you're using the lower port the oil will go out the breather hose before it has a chance to go back through the drain hole. One way to deal with this (IronMick's idea I believe) is to run that hose all the way to the end of your exhaust bracket - that way any oil that drips out won't end up on your rear tire.
In Late 82 they upped the size of the oil slinger washer to 1-3/4", so that might be something to consider doing. Stock 79 washer is only 1-5/8".
Yes you can see the breather valve if you remove the generator, but even the FSM doesn't have a way to test it so I don't think it would help you much.
I wouldn't point the hose up if you're using the lower port. Oil will pool at the low point and stop the airflow. The outlet of the lower breather port is below the oil drain hole, so there's no way for that oil to get back into the gearcase.
Old 11th June 2021
Ill look into the washer change as you were talking about. Mine is a 79. Im not sure what you mean lower port. Im talking about the port on the upper case where the generator is located. Ill have to look for Mics post about the breather routed to the back as well.
Old 11th June 2021
BigMek's Avatar
There are two connections for the breather, one at 6 o'clock and one at 10 o'clock as viewed from the right side of the bike. Originally the 10 o'clock port would have been routed into the air cleaner and the 6 o'clock port would have been plugged, but a lot of people switched them for looks.
Edit: Photo from the Sportsterpedia showing both connections.
http://sportsterpedia.com/lib/exe/fe...2_by_83xlx.jpg
Old 11th June 2021
Fivecats's Avatar
Fivecats Fivecats is offline
Sportster/Buell Year: '68
Sportster/Buell Model #2: FXR
Sportster/Buell Year #2: '89
Other Motorcycle Model: R50/5
Other Motorcycle Year: '73
Fivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond repute
Great stuff here...
Old 12th June 2021
Ok so i took her for a ride, and as it sits and idles you hear almost a squeek sound coming from the port, oil still coming out, no blue smoke out of the tail pipes if i cover the hole shes def pumping air. Once it cools off im gunna pull the genny and check the washer and make sure its ok and not getting loose as wrll. Im getting to that im stumped point.
Old 12th June 2021
Supposedly you can skeet a little WD-40 in the breather hole (those with a reed valve only) to clear it out.
Here is the IH breather valve page in the Sportsterpedia.
http://www.sportsterpedia.com/doku.p...k:ih:engmech07
Unless the stainless steel reed is broke, it may just have junk under it keeping it from working right.
It should pump at pulses .... especially at idle. It's not good to cover the hole.
The reed is suppose to close on upstroke and open on downstroke.
The motor should have a slight vacuum in the crankcase due to the reed working properly.
Old 12th June 2021
randy3934's Avatar
just how full is your oil tank?
Old 12th June 2021
The tank is about a quarter way up over the lower index. After ive ran it a few times and rechecked to make sure its not overfull.
Old 12th June 2021
IronMick's Avatar
IronMick IronMick is offline
Rider Of The Iron Steed
That squeak you are hearing is common, it is the reason the valve is called a foo-foo. It is an indication that the valve itself is crudded up somewhat and needs to be cleaned. I have treated it exactly as Hippysmack recommends, with a squirt of WD-40.
Mick
IronHead Forever!
Visit Mick's WebSite
[And Check Out My Autobiog]
