0 Evo sportster Ignition Modules
Last Post: Stojan85
Last Post: jeffro57
0 best set up for ease of kick starting
Last Post: clivelive
0 Tuning a keihin butterfly
Last Post: shivaspear
0 '74 Front Brake Caliper leaking
Last Post: dtwaddell42
0 1960 XLH Stroker – a 13 year journey
0 71 XLH Value?
Last Post: joe s
0 60’s XLCH front tyre
Last Post: davixlrtt
0 72 ih stroker advise needed
0 Allegheny National Park III
0 Hello from CT
Last Post: fafcpa
0 Aftermarket nose cone module vs aftermarket under seat module
0 Had to wait for the snow to fall to pick up my 73
Last Post: Andy56
0 NOS cases
Last Post: BillPlayfoot
0 Facebook sales listing
0 Lectron Carbs: anyone used them?
0 Exhaust compatability?
Last Post: Racepres
0 2021 Iron Butt Rally
ebikerman (85), nalakk (80), blkjak (78), Dave.N (67), cousincletus (61), stretch7 (59), jockeyshift (57), juice900 (43), sportsterwheelies (41), live_loud (39)
gearing, gears, ratios, transmission
Old 17th September 2021
groovemeisterus's Avatar
groovemeisterus groovemeisterus is offline
Sportster/Buell Model: XL883-1200 Branch Build
groovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant future
Default What happened to 6 speed transmissions and Sportgear?
2000 sportster 883-1200
Was gathering parts list for my re-build from rebuilt crank assembly and up since cases are already have everything out and split.
Started looking into the Baker XL6 transmission, but they are discontinued. Then went to look for the SportGear, Their web sight is down, and can't find info except from their archives on their websight with gear ratios.
Tried Ebay for used Baker XL6 transmission and couldn't find one. Found some from other countries, but not sure I would trust a new one costing that much, and shipping.
Then heard RevTech made a 6 speed from googling around and reading from posts and couldn't find info on that ?
Gonna go out on a limb and ask if it is technically possible to convert stock 5 speed to 6 speed ?
Or is there another manufacture that makes one similar to Baker ?
Maybe a way to get the main part, think called trap door or dog house part and buy pieces up and make one ?
Any ideas or other 6 speed trasnmissions would be great since would like to finally while cruising with stock 883 gearing not feel like I need another gear, and so far the Baker XL6 has the best or same ratios i'm used to, and then the 6 gear ratio of I believe 0.86:1.
Thanks for any info, and i'm still looking and changing google search terms cause that sometimes brings up more or different result that might lead to something else.
Thanks,
883 XL Y2K - BLACK,Ported Manifold,HSR 42mm Carb,Branch #5 Ported 883 Heads,Bob Woods W8S 0.590" Cams, SE -0.050" Perfect Fit Pushrods,SE 1200 Ignition Module ,Vance & Hines Straight Shot Exhaust,07 SE Air Cleaner,SE 40,000V Red Perf Coil,883 Jugs Precision Bored for Branch 30º Domed Pistons,& One Big Smile ;o), ~83TQ, ~83HP for now.
Old 18th September 2021
Some of the aftermarket suppliers offered the Baker 6speed in the past, give the a holler and see if they hav3 any remaining? Nothing ventured nothing gained.
I.B.A.#26543,
rejeanprimeau's Avatar
After that, you'll be looking for a seventh gear. Why you need a 6 gears tranny???
Same final ratio.
Randy_rots Randy_rots is offline
Sportster/Buell Model: XL 1200 softail frame&NOS
Sportster/Buell Model #2: Buell XB1250 Uly XT
Randy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant future
Same final ratio.
Baker XL6 is an overdive tranny, 0.86 to be exact.
And it's a great addition for modded bike.
decman decman is offline
Post no Avatars!
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
I had a Baker XL-6 in my 2003 1200C and I liked it.
But I never used 6th unless I was on the interstate doing 70+.
Baker was the only one that I knew of that made one for the Sportsters.
You "could" make one if you had a lot of extra cash and a machine shop.
If your engine had performance mods to it, I would look at the easier
and cheaper path of changing the final drive pulley (sprocket) ratio
for the lower RPM at higher speeds.
Do you have the 29T or 27T front sprocket?
BTW with my 2001 XL1200S, I never fitted my XL6 to it becuase it ran
just fine at the higher RPMs. It likes running 65 in 4th.
BTW, I've worked on 3 or 4 Sportsters that run at Bonneville (and have world records, 165MPH and higher)
and all of them run stock 5-speeds.
No wonder, with over drive gear you lose power.
However on the street that over drive 6th is great for cruising.
Have already started and awaiting response. Thanks
Same final ratio.
883 gearing is lower than 1200 with a 29T engine belt sprocket. Don’t want to have my odometer recalibrated for speed and miles till next tank fill up.
Although same transmission, over all gearing is taller on a 1200, which is why a 883-1200 conversion is better off the line. Just not interstate speeds without vibrating teeth.
Could also try and find replacement parts to try and build one. I have the 27T. If went to 29T odometer would be off on speed and also mileage.
With the overdrive I could still get off line faster, and cruise 70+ on interstate without vibrating teeth. And way smoother.
Best of both worlds.
Thanks
F.W.I.W. my 2000 was a strong vibrator, when it got 10 1/2:1 pistons and n4 cams it smoothed out some, then when it ingested an 89” S&S kit it became noticeably smoother. Just saying.
