0 My Iron
0 Sparkplugs & Sparkplug Wires
Last Post: ReddTigger
0 Bad Primary Oil Leak
Last Post: ezmerf
6 SPORTY BOBBER PICTURES
0 dual carb heads on ebay
0 Helmets Please...
Last Post: webman94
0 Need help with S&S GB carb
Last Post: RKN
0 Lake Ozark Bikefest
Last Post: Bow only
0 The TAT Sportster
Last Post: steveolds
0 Have my cake and eat it too? 1275 + 570s + CVJ
0 70 XLCH Piston, Connecting rod issue
Last Post: Wilkinson949
0 An Ohio Meet 'N' Eat
Last Post: gravydog
8 Never Forget
Last Post: joes95bobber
Last Post: Hellbent_4
Last Post: Dave48
14 98 just upgraded to 1250 from 1200
Last Post: SeaCur
0 Tour of Honor
0 hmmm, whaddaya think? (Footpeg Location)
Last Post: slcharger
0 Further forward mids on pre-2014 models
0 7” Headlight conversion on solid mount
0 Finally back in the red zone
Last Post: smm1200
0 Buell heads and cams!
Last Post: smm1200
Wot the tiny 20 gage earth wire from a tickle pickle charger...yes i did.
You're right. Pigtails for a 1 amp tender should be 10 ga. How could I have overlooked the obvious.
wedge's Avatar
wedge wedge is offline
Flashing red light indicates that the AC is hooked up correctly, and the Battery leads are either not hooked up correctly OR... The battery is really discharged (like below 3V).
So you can leave it hooked up for a bit and see if that red light gets to where it stays on steady (that means it's charging now). If the red light continues to flash after about an hour or so, then that battery may be toast.
Try hooking it up to your car battery just to see if it acts normal on there.
I have had batteries where the tender flashed for a while, then went solid red and all was good.
wedge's Avatar
You did clip the leads directly to the battery posts, so the size of your adaptor leads isn't the issue.
I personally ditch the Jap looking side covers (I think they look silly on a Harley and just get in the way), and then I just clip my tender on whichever bike I am not using at the moment. I use the Positive battery post, and the closest head bolt for ground.
