0 My Iron
0 Sparkplugs & Sparkplug Wires
Last Post: ReddTigger
0 Bad Primary Oil Leak
Last Post: ezmerf
6 SPORTY BOBBER PICTURES
0 dual carb heads on ebay
0 Helmets Please...
Last Post: webman94
0 Need help with S&S GB carb
Last Post: RKN
0 Lake Ozark Bikefest
Last Post: Bow only
0 The TAT Sportster
Last Post: steveolds
0 Have my cake and eat it too? 1275 + 570s + CVJ
0 70 XLCH Piston, Connecting rod issue
Last Post: Wilkinson949
0 An Ohio Meet 'N' Eat
Last Post: gravydog
8 Never Forget
Last Post: joes95bobber
Last Post: Hellbent_4
Last Post: Dave48
14 98 just upgraded to 1250 from 1200
Last Post: SeaCur
0 Tour of Honor
0 hmmm, whaddaya think? (Footpeg Location)
Last Post: slcharger
0 Further forward mids on pre-2014 models
0 7” Headlight conversion on solid mount
0 Finally back in the red zone
Last Post: smm1200
0 Buell heads and cams!
Last Post: smm1200
  #81
Old 27th October 2009
Don Burton's Avatar
Don Burton Don Burton is offline
Sportster/Buell Model: XL 1200 Gone
Don Burton has a reputation beyond reputeDon Burton has a reputation beyond reputeDon Burton has a reputation beyond reputeDon Burton has a reputation beyond reputeDon Burton has a reputation beyond reputeDon Burton has a reputation beyond reputeDon Burton has a reputation beyond reputeDon Burton has a reputation beyond reputeDon Burton has a reputation beyond reputeDon Burton has a reputation beyond reputeDon Burton has a reputation beyond repute
I just found an answer to my question. http://www.nrhsperformance.com/image...ricaneflow.gif
Old 22nd May 2010
DriverSound's Avatar
DriverSound DriverSound is offline
Sportster/Buell Model: XL883N
Sportster/Buell Model #2: XL1200X
Sportster/Buell Year #2: 2010
DriverSound is an unknown quantity at this point
From my experience coming from the automotive side is that the stock air filter is not at all that bad. I've read many independent test results testing all the main aftermarket brand out there and found that most do flow more air but when it comes to trapping dirt, simply put-they sucked. K&N was one of the worst out there for filtering or lack of. After some research, there are really not much choice for us in air filtration. Ninety percent of AC manufacturer out there uses K&N. I tried to approach AFE (http://afepower.com/) to see if they will develop motorcycle filters and they said not currently. AFE Pro Dry filter tested as one of the better filtering media out there that flowed better than stock and trapped more dirt than stock. I know that Screamin Eagle uses a dry filter but unfortunately, I couldn't find a test that involved them. I'd stick to stock or SE before K&N. There are others out there like NRHS but again, I couldn't find actual filtration results but I do know that use a comparable setup like K&N. There's a balance between flow and filtration. We just have to find it.
Joe_jeep's Avatar
Joe_jeep Joe_jeep is offline
Joe_jeep has a brilliant futureJoe_jeep has a brilliant futureJoe_jeep has a brilliant futureJoe_jeep has a brilliant futureJoe_jeep has a brilliant futureJoe_jeep has a brilliant futureJoe_jeep has a brilliant futureJoe_jeep has a brilliant futureJoe_jeep has a brilliant futureJoe_jeep has a brilliant futureJoe_jeep has a brilliant future
we seldom ride our bikes off road i assume.
the environment they are used in is fairly clean compared to a jeep or truck.
a performance filter will let through a bit more dirt that is very small.
i doubt it will effect the longevity of a hd motor much. jmho
even a stock filter will let through small enough particles.
you can have air filtration without media by using forces of nature or creating them.
aircraft is a good look-see for how it is done.
after-all do you want a 750hp turbine zoonk out mid-flight due to a plugged media???
Ireeman's Avatar
Ireeman Ireeman is offline
Asgardian
Sportster/Buell Model: 883r
Other Motorcycle Year: abov
As an FAA fuel system repair station machinist...i can say there is quite a bit of shit that gets through system. It does horrible damage. AL parts are fragile, but it is difficult to build Monel based planes that have range and capacity.
there is no doubt there for sure. most of what i have been around do not even use inlet shielding, just have a particle separator using bleed air switched on in dusty environments.. then again, they are restricted to run hours. on the industrial side we based of TOT and you could get better than a year or more 24/7 run time only down for water wash and maintenance.
