0 My Iron
0 Sparkplugs & Sparkplug Wires
Last Post: ReddTigger
0 Bad Primary Oil Leak
Last Post: ezmerf
6 SPORTY BOBBER PICTURES
0 dual carb heads on ebay
0 Helmets Please...
Last Post: webman94
0 Need help with S&S GB carb
Last Post: RKN
0 Lake Ozark Bikefest
Last Post: Bow only
0 The TAT Sportster
Last Post: steveolds
0 Have my cake and eat it too? 1275 + 570s + CVJ
0 70 XLCH Piston, Connecting rod issue
Last Post: Wilkinson949
0 An Ohio Meet 'N' Eat
Last Post: gravydog
8 Never Forget
Last Post: joes95bobber
Last Post: Hellbent_4
Last Post: Dave48
14 98 just upgraded to 1250 from 1200
Last Post: SeaCur
0 Tour of Honor
0 hmmm, whaddaya think? (Footpeg Location)
Last Post: slcharger
0 Further forward mids on pre-2014 models
0 7” Headlight conversion on solid mount
0 Finally back in the red zone
Last Post: smm1200
0 Buell heads and cams!
Last Post: smm1200
  #6331
Old 3 Days Ago
Momentary Specialist
Sportster/Buell Year: 96
Other Motorcycle Year: 99
This week.
Fabricated and installed an air cleaner.
Removed the exhaust and test fitted a 2-1(needs mods to fit) put the original exhaust back on with new gaskets, Repaired a heat shield, put better condition used SE mufflers on.
When the exhaust was off, I purged and bled the rear brake fluid. Cleaned the engine and frame, polished the cases.
Then installed an LED taillight bulb.
Sleepy Labeef rides again!
Old 3 Days Ago
Lone Rider's Avatar
Sportster/Buell Model: 1200
Very cool Highly Dangerous, however; I want to see pics of it out on the road.
Old 1 Day Ago
Installed a 7”, “modern British” style headlight and brackets, removed the eyebrow in the process and mounted the speedo , tach, idiot light assembly to the triple tree on short spacers.
Old 1 Day Ago
xElvis's Avatar
xElvis xElvis is offline
Sportster/Buell Model: XL883
xElvis has disabled reputation
Changed the oil, added a touch of transmission oil til I solve that leak, and swapped out the headlight for a newfangled LED unit from online. Product review after a week or two of riding it. For now... BRIGHT!
xElvis - DOT Certified Cage-Free - '08 883 ~100k miles
Old 6 Hours Ago
ParrotHead's Avatar
I am the great Cornholio!
Other Motorcycle Year: 1974
Added 2,400 miles to my 07 Sporty
Dropped off my forks for the 06 Sporty at the Indy to get checked out to see why they are so soft and if I damaged them by bottoming them out several dozen times during the Iron Butt Rally
John Wayne - "The Shootist"
Old 6 Hours Ago
harley506d's Avatar
Sportster/Buell Model: 1200c
Replaced loose rivets on my new front fender with dome heads and nylocks.
Old 4 Hours Ago
After loading Black Beauty for the run out of the Country to the Friday the 13th Port Dover Rally I had a four hour delay. The SuperTrapp exhaust had completely fractured through in front of the muffler, no way was Canada going to allow that kind of noise. Got a ride to storage from a friend, pulled the SuperTrapp off of Orange, along with its mount, installed on the black bike and crossed the ?River to a great weekend!
Old 2 Hours Ago
boomerguy boomerguy is online now
It may just be old fluid. When I changed mine (stock E type) to new AMSOIL SHOCK THERAPY Suspension Fluid #10 Medium (E type) it made a world of difference. It was bottoming out and afterwards it was very plush and never bottoms out. The fluid had 10K miles on it because that's how many miles the bike had on it, but was 18 years old and was watery, black and stunk worse than a dead skunk. I don't know if Amsoil is better than stock Harley fluid but I plan to keep using it after these results. AND I plan to change it every 10K miles or 2 years, just to be safe.
