0 I bought a Sportster last month, but I don't know what to do now, when it leaked the
0 1979 iron head sportster exhaust
Last Post: bill smith
0 Easy start cam choice
Last Post: 11B40
0 Help & advice needed
0 Wire wheel hubs
Last Post: LenC
0 teflon buttons or circlips?
Last Post: thefrenchowl
0 Single fire dual fire ignition
Last Post: The Doctor71
0 Sources for new/used cast front wheels
Last Post: speedyrette
0 2008 xl1200c
Last Post: Tyler45
0 The Strociek Project
0 Best head casting for porting Question
0 Upper Support Bracket Installation
0 Where To Get Free Air
Last Post: RockerRider
0 My 99 883 c
Last Post: 99-883-c
Last Post: IvanIron
0 Engine oil getting into primary help
Last Post: andy2175m4
0 Timing question
0 Chevelle's Dry Clutch Worm Gear Upgrade
Last Post: Monte03
0 xlh 1000 1972 first project
yeller1200, IronMick (79), painter (72), motobob883 (69), rickxx (67), MRCLEEN (49), Wetcheez (48), hello_shoes (41)
battery box, chopper, hardtail, oil tank, rigid
Kickflippin Kickflippin is offline
Sportster/Buell Year: 1976
Other Motorcycle Model: Yamaha XS650
Other Motorcycle Year: 1978
Kickflippin is an unknown quantity at this point
Default Paughco single loop frame mounting ideas
I'm trying to find a good looking way to mount up a battery and oil tank to this Paughco single loop frame. Dropping a '91 motor in it. I was hoping to get the battery into a BT horseshoe tank I already have but nothing really lines up without having to place a bunch of mounting tabs for support. plus it sticks out too far on the sides.
I can track down a cylinder style oil tank, which will be alot easier to mount, but this frame doesn't leave much room to mount a battery in front of the rear fender, Also, the fender support is angled so event a small battery sits crooked.
I know this is simple stuff but I'm just out of ideas for now. Appreciate it. And... sorry for the giant pictures.
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Well. All I can post is my mockup . Everything mounts behind the center post anyways . Whether single downtube custom hardtail or stock weld on hardtail on stock frame.
Edit: For a battery idea. That battery you show us overkill < Godzilla>. I'd look into getting smaller lithium battery myself. With lots of cranking amps.
Traveled to
zimbros12's Avatar
zimbros12 zimbros12 is online now
Sportster/Buell Model: XLH 1200 Hardtail
zimbros12 is a splendid one to beholdzimbros12 is a splendid one to beholdzimbros12 is a splendid one to beholdzimbros12 is a splendid one to beholdzimbros12 is a splendid one to beholdzimbros12 is a splendid one to beholdzimbros12 is a splendid one to beholdzimbros12 is a splendid one to beholdzimbros12 is a splendid one to beholdzimbros12 is a splendid one to beholdzimbros12 is a splendid one to behold
kitabel kitabel is online now
Sportster/Buell Year: 1989
I can't quite see the individual molecules, need bigger pictures.
Les59 Les59 is offline
Sportster/Buell Model: xlh1100
Sportster/Buell Year: 1986
Les59 is an unknown quantity at this point
If it absolutely won't fit anywhere else I would be tempted to strengthen and modify a swingarm bag and put it there.
Uberstorm Uberstorm is offline
Sportster/Buell Year: 1979
Sportster/Buell Model #2: ironhead
Sportster/Buell Year #2: 1979
Uberstorm has much to be proud ofUberstorm has much to be proud ofUberstorm has much to be proud ofUberstorm has much to be proud ofUberstorm has much to be proud ofUberstorm has much to be proud ofUberstorm has much to be proud ofUberstorm has much to be proud ofUberstorm has much to be proud ofUberstorm has much to be proud ofUberstorm has much to be proud of
i built a belly pan and fitted a litium in there and alarm n charge point etc, i also added a on off switch so i dont have to remove the belly pan if i need to do some electrical work. Fuses in the head mounting
http://xlforum.net/forums/attachment...3&d=1631405508
You may find that seat + position impractical. As the coil springs compress, you slide off the back. That's why seats are usually angled up in the rear, have a raised back, or both.
bill smith bill smith is online now
Sportster/Buell Year: 1971
bill smith has disabled reputation
cut that lower fender support out and start over. you can incorporate a fender support into the battery box/tray. just make sure you can slide the batt. out the left side easily.
Andy Hog's Avatar
Andy Hog Andy Hog is offline
Sportster/Buell Year: 1981
Other Motorcycle Model: 1964 Triumph 3TA
Andy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant future
Hi,
have you considered putting the full motor in the frame & seeing if a horseshoe oil tank that has the battery compartment integrated in to it will fit behind the engine?
Andy.
Old 6 Days Ago
Paughco May be able to make recommendations?
I.B.A.#26543,
