1 Week Ago
Posts: 4,718 Sportster/Buell Model: XLB, XLCH, Sporton Sportster/Buell Year: 1962 Sportster/Buell Model #2: XLCH Sportster/Buell Year #2: 1966 Other Motorcycle Model: XLCH (Another one) Other Motorcycle Year: 1966
Sorry, corrected cranking pressure.
There are a lot of ways to specify how much pressure your engine makes - static, dynamic, effective , corrected.
Most guys just give a nominal static figure which is based on the physical dimensions of the engine. But there are a lot of variables that determine what you finally end up with when the engine is turning over and even more when it's running.
I do a base line measurement using the same procedures every time so I can "estimate" what's happening or happened inside the engine in between rebuilds.
A LOT if Ironhead owners change the cams and they can have a dramatic effect on compression achieved. Generally, they shouldn't.
Funnily enough HD got the cam design pretty well right from the start. Guys want to drop in a set of cams to "go faster" and it so often leads to disappointment.
1 Week Ago
Chief of Security
Posts: 2,326 Sportster/Buell Model: 1200/1250C Sportster/Buell Year: 05
Often times that's the case. Giving up power somewhere to gain it elsewhere. There are exceptions tho as I mentioned.
Not sure about in your world...
1 Week Ago
Posts: 1,309 Sportster/Buell Model: xlch Sportster/Buell Year: 1964 Sportster/Buell Model #2: XLCH IR EFI Sportster/Buell Year #2: 1971 Other Motorcycle Model: BMW K1200RS Other Motorcycle Year: 2001
Originally Posted by mickey t
I got it kicked over 4 times in a row...twice last night twice this am...changed my starting procedure...key off start/choke up 2prime kicks..then key on and twist throttle a tiny bit n she kicked over on the 2nd kick each time...
Sent from my SM-J260A using Tapatalk
What a concept...
Get it warmed up proper when you get your clutch fixed and then set your idle speed. Sounds like your getting it now.
