0 stress killer
0 hi all
Last Post: ironmanx
0 supply oil line seeping
Last Post: hexnut
0 New Member and a question
0 3.5" straight riser
0 Speedometer Interchangeability Between Different Generations.
Last Post: denguy
0 77 XLH Starting issues no needle bearing in primary?
Last Post: MadMike_1126
0 Starter bushing/bearing install in primary cover
0 Keep the V&H head pipes or go stock?
Last Post: 84cj
0 question for our machinists
Mr. Lynn (73), dentat2 (49), OWNED13 (46), knolan.smith (41), Malicious44 (34)
Old 27th May 2018
Default 900 heads contd..
I replaced the braided steel oil lines I put on back in the '80's with oem style rubber hose. IMG_0053 (1) by Bruce Stoudt, on Flickr IMG_0066 by Bruce Stoudt, on Flickr a -52 oem brake rod to replace the chroIMG_0067 by Bruce Stoudt, on Flickrme one I put on in the '90's.parkerized. the reworkedIMG_0056 by Bruce Stoudt, on Flickrd XLR heads by mrmom9r. exhaust port. IMG_0059 by Bruce Stoudt, on Flickr intake port. IMG_0058 by Bruce Stoudt, on Flickr Kibblewhite -R valves 1.950 int. 1.750 ex. IMG_0057 by Bruce Stoudt, on Flickr IMG_0065 by Bruce Stoudt, on Flickr silver paint and stub fins.my 1960 XLCH has it's 900 heads back again.
Old 27th May 2018
Magneto Sportster's Avatar
Magneto Sportster Magneto Sportster is offline
Sportster/Buell Year: 1969
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1960
Other Motorcycle Model: XLCH
Other Motorcycle Year: 1959
Magneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond repute
Looks great, when are you bringing it back to a GBB?
"Ride 'em, don't hide 'em!"
Old 27th May 2018
thank's.J.J.it wasn't done in time for the recent one.maybe the next one if I don't blow it up first.get's up in the r.p.m.s much quicker now!
Old 27th May 2018
spacecoast spacecoast is offline
Sportster/Buell Model: 883
Sportster/Buell Year: 1989
spacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant future
Hey Bruc, what else, besides the heads, have you done motor wise?
Sharp bike man.
Old 27th May 2018
thanks spacecoast.have you read my signature at the bottom of my post?
Old 28th May 2018
Got distracted by the eye candy.
Old 28th May 2018
Keithybloodygeorge Keithybloodygeorge is offline
Sportster/Buell Year: 1967
Keithybloodygeorge is a jewel in the roughKeithybloodygeorge is a jewel in the roughKeithybloodygeorge is a jewel in the roughKeithybloodygeorge is a jewel in the roughKeithybloodygeorge is a jewel in the roughKeithybloodygeorge is a jewel in the roughKeithybloodygeorge is a jewel in the roughKeithybloodygeorge is a jewel in the roughKeithybloodygeorge is a jewel in the roughKeithybloodygeorge is a jewel in the roughKeithybloodygeorge is a jewel in the rough
Very sexy Bruce! Are those ports welded to get that shape? Looks like there's a different colour metal in there but hard to say for sure from the photos
Sent from my Pixel using Tapatalk
Old 28th May 2018
mct496's Avatar
mct496 mct496 is offline
Sportster/Buell Model #2: 84 xl paughco rigid
Other Motorcycle Model: 70 xlch
mct496 is a name known to allmct496 is a name known to allmct496 is a name known to allmct496 is a name known to allmct496 is a name known to allmct496 is a name known to allmct496 is a name known to allmct496 is a name known to allmct496 is a name known to allmct496 is a name known to allmct496 is a name known to all
Default i know mom9r did the port work
he do the bolt hole ,oil drain relocation and fire ring counter bore enlargement to make the xlr's fit your 1000 cyls you still running the early 1000 cyls or did you get a later set while you had her tore apart?
Old 28th May 2018
I don't think that's necessary on a motor this size.Don didn't mention welding.he did mention years ago that brazing rod was the filler material of choice. that would be very easy to spot.
Old 28th May 2018
Yeah that would be easy to spot Bruce. There does seem to be quite a different shape to the port as it goes towards the chamber. I guess that's the D shape that's meant to flow so well
Whatever the case this is a very cool and desirable ride Bruce. I love that you've got the 900 heads back on there, looks so stock but it's anything but
