0 Getting Hammered
Last Post: kltrkmpf
0 Leineweber camshaft
Last Post: chevelle
0 question for our machinists
Last Post: JonesL
0 More oil return questions
Last Post: Scott
0 WTB: Sportster Shift Lever
Last Post: tussuck
0 Mid or forward controls.
0 2015 sportster charging
Last Post: Scott
0 Cheap 7200B bearing = NO!
Last Post: Roane
7 Ironhead yes or no
0 New Member and a question
0 piston rings
Last Post: Sprtstr1200s
0 New member softail rim laced to sportster hub
0 Cold weather pants:
Last Post: RDHenley
0 Electrical question
Last Post: RDHenley
2 Humble pie
Old 19th June 2018
chevelle's Avatar
chevelle chevelle is offline
Sportster/Buell Year: 19**
Sportster/Buell Year #2: 1965
With 52....?
Old 19th June 2018
Magneto Sportster's Avatar
Magneto Sportster Magneto Sportster is offline
Sportster/Buell Year: 1969
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1960
Other Motorcycle Model: XLCH
Other Motorcycle Year: 1959
Magneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond repute
#52 goes around the support tube pointing up. #51 goes around the exhaust pipe sticking down. The tabs are facing each other and get bolted together.
"Ride 'em, don't hide 'em!"
Old 19th June 2018
brianbbs67's Avatar
I have been revived
Sportster/Buell Year: 1961
Sportster/Buell Year #2: 1970
Other Motorcycle Year: 1977
Bruce, You are really going after your bike. Looks so different and better. Great job. Yes, 51 and 2 go together as stated.
Ok, now I'm revived
Old 19th June 2018
thanks guys.i might have those pieces.my main concern is the front pipe.i bought the bracket for that,should have it on tomorrow morning.i had it on once,but it needed to be flipped 180 degrees.
Old 20th June 2018
I put the mid bracket on the front pipe this morning.maybe i'll post a pic.it's the same side as the other 2 pics.i checked out the location for the mid bracket on the rear pipe,it's only about 6'' away from the rear one.seems unnecessary and overkill.i needed the mid bracket on the front pipe because it got blown off twice when I jump on it hard.donr's port work and the 1-3/4'' R exhaust valves made a big difference in the exhaust flow out of the pipes.
Old 20th June 2018
if anyone wants to see another pic,speak up.
Old 21st June 2018
simonster123's Avatar
simonster123 simonster123 is offline
simonster123 is just really nicesimonster123 is just really nicesimonster123 is just really nicesimonster123 is just really nicesimonster123 is just really nicesimonster123 is just really nicesimonster123 is just really nicesimonster123 is just really nicesimonster123 is just really nicesimonster123 is just really nicesimonster123 is just really nice
I would be interested to hear from Don on the nature of the porting of the XLR heads.
I'm guessing that they were originally ported by Branch for the factory, and that served them well for TTs and other off-road events of the time?
I am curious as to what was done by him (without giving away too much proprietary info) to the existing port job to change it. What was your stated purpose of the work, Bruce? To gain a faster street machine with power further down the band, or to flow even more air for a stroker, or?
It sure would be interesting to know a bit more about the difference and results of the different styles of porting.
And more pics of that sweet machine certainly couldn't hurt!
Old 21st June 2018
faster street machine yes,but mostly the port flow(cfm)needed to be increased to match the larger displacement.Don told me the XLR heads were fine for a 900,but not a 1200.i found the o.e.m. bracket for the rear pipe.maybe I can make that work.it will make the pipe lower which might cause kick lever interference.which is why the bracket I have on there now is on.
Old 21st June 2018
i tried the o.e.m. bracket at the end of the rear pipe.no dice.the pipe runs too high for it.the reproduction XLR pipes don't fit as well as the o.e.m.raining this morning,so no riding to work,which means no pic today.maybe tomorrow.
Old 22nd June 2018
mrmom9r's Avatar
mrmom9r mrmom9r is offline
Regarding the head work. It's like Bruce said, the XLR heads are optimized for a 900cc engine.
For a 1200 , 10 to 12 more cfm is required to make good power up to 6500 rpm.
The larger motor also likes a little more port volume. The Branch heads are technically correct shape-wise so it's just a matter of carefully scaling them up for more volume and flow while keeping the width , height , and valve bowl of the ports in proportion .
Sounds simple enough.
