0 stress killer
0 hi all
Last Post: ironmanx
0 supply oil line seeping
Last Post: hexnut
0 New Member and a question
0 3.5" straight riser
0 Speedometer Interchangeability Between Different Generations.
Last Post: denguy
0 77 XLH Starting issues no needle bearing in primary?
Last Post: MadMike_1126
0 Starter bushing/bearing install in primary cover
0 Keep the V&H head pipes or go stock?
Last Post: 84cj
0 question for our machinists
Mr. Lynn (73), dentat2 (49), OWNED13 (46), knolan.smith (41), Malicious44 (34)
mickey t's Avatar
mickey t mickey t is offline
Sportster/Buell Model: ironhead sporty
Sportster/Buell Year: 79
mickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud of
Default Compression test results
Ok so I'm ready to hang myself...compression test on rear cylinder was 80 and front was 75..so I have a problem yeah guys?? Thoughts, suggestions cause I have no idea ....but glad I did it...freaking timing was good the whole time I'm sure...
Sent from my SM-J260A using Tapatalk
Worn Rings or Worn Valves (or hanging up - or not adjusted correctly)...
Leak Down Test should provide the source of lost compression...
http://sportsterpedia.com/doku.php/t...:ref:svcproc21
mickey t's Avatar
Lead Down Test should provide the source of lost compression...
I just put a bit of oil in the spark plug holes....it went up a bit...rear went to 115 n front at around 105
mickey t's Avatar
Now w that I'm suspecting valve because it's the rings that seal yeah? But if ya go n put new valves wouldn't ya do new rings too since your there?
Hopalong48's Avatar
Hopalong48 Hopalong48 is offline
Sportster/Buell Year: 1966
Hopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to behold
Did you do a dry and then wet test, with WOT?
Sent from my SM-G975U using Tapatalk
adding the oil effects ring seal (improves) does not effect valve seal.double check your pushrod adjustment.too tight and the valves won't close,losing compression.you mentioned they were too tight before.
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
What compression tester are you using? It it doesn't have a schrader valve in the end of the hose that screws in the head, it's going to read low.
doodah man's Avatar
It will also read low if the engine is not warmed up.
mickey t's Avatar
It's got the Schrader valve on side so just push in and releases the pressure
mickey t's Avatar
I'll double check but they were adjusted about a month ago
