0 Getting Hammered
Last Post: kltrkmpf
0 Leineweber camshaft
Last Post: chevelle
0 question for our machinists
Last Post: JonesL
0 More oil return questions
Last Post: Scott
0 WTB: Sportster Shift Lever
Last Post: tussuck
0 Mid or forward controls.
0 2015 sportster charging
Last Post: Scott
0 Cheap 7200B bearing = NO!
Last Post: Roane
7 Ironhead yes or no
0 New Member and a question
0 piston rings
Last Post: Sprtstr1200s
0 New member softail rim laced to sportster hub
0 Cold weather pants:
Last Post: RDHenley
0 Electrical question
Last Post: RDHenley
2 Humble pie
mickey t's Avatar
mickey t mickey t is offline
Sportster/Buell Model: ironhead sporty
Sportster/Buell Year: 79
mickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud of
Originally Posted by Hopalong48 View Post
Did you do a dry and then wet test, with WOT?
Sent from my SM-G975U using Tapatalk
Yes dry first then a shot of my oil in there which help seals the rings better and got a higher reading
Sent from my SM-J260A using Tapatalk
mickey t's Avatar
Originally Posted by doodah man View Post
It will also read low if the engine is not warmed up.
Yeah I read that last night but this is what it is...
1/2 hour ride out if city traffic. Running it in the shop does not count
And of course, throttle and choke plate wide open during test.
EDIT: If it was not warmed up then anything over 80 or 90 is good. Best to do a properly warmed up test when it is convenient.
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
If the schrader valve is on the side of the gauge and not the end of the hose, you're adding the volume of the hose to the volume of the combustion chamber. I'm not talking about the release.
Mine was a difference of 45psi. Big difference.
Longer the hose, the lower it reads.
Hopalong48's Avatar
Hopalong48 Hopalong48 is offline
Sportster/Buell Year: 1966
Hopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to behold
If oil improved the compression I believe that indicates worn rings. a bad intake valve could cause a cough from the carb or throttle body. Bad exhaust valve is harder to detect.
What engine do you have? mileage? model year? any blue smoke from the exhaust? Plugs fouling?
I like to write down everything that seems to be wrong and then see how it all connects.
mickey t's Avatar
71 xlch Ironhead 900cc...mileage unknown..no blue smoke at all when it kicked over ...n yes oil improved it
mickey t's Avatar
Good call...hose is about a foot long
mickey t's Avatar
Ok so didn't open choke...open throttle on second go...saw on video by low brow.
mickey t's Avatar
Ok so I'm over the 80 or 90 after oil was added so I'm the thinking rings??
mickey t's Avatar
No plugs fouling
