0 Getting Hammered
Last Post: kltrkmpf
0 Leineweber camshaft
Last Post: chevelle
0 question for our machinists
Last Post: JonesL
0 More oil return questions
Last Post: Scott
0 WTB: Sportster Shift Lever
Last Post: tussuck
0 Mid or forward controls.
0 2015 sportster charging
Last Post: Scott
0 Cheap 7200B bearing = NO!
Last Post: Roane
7 Ironhead yes or no
0 New Member and a question
0 piston rings
Last Post: Sprtstr1200s
0 New member softail rim laced to sportster hub
0 Cold weather pants:
Last Post: RDHenley
0 Electrical question
Last Post: RDHenley
2 Humble pie
  #201
Ferrous Head's Avatar
Sportster/Buell Year #2: 1966
Sorry, corrected cranking pressure.
There are a lot of ways to specify how much pressure your engine makes - static, dynamic, effective , corrected.
Most guys just give a nominal static figure which is based on the physical dimensions of the engine. But there are a lot of variables that determine what you finally end up with when the engine is turning over and even more when it's running.
I do a base line measurement using the same procedures every time so I can "estimate" what's happening or happened inside the engine in between rebuilds.
A LOT if Ironhead owners change the cams and they can have a dramatic effect on compression achieved. Generally, they shouldn't.
Funnily enough HD got the cam design pretty well right from the start. Guys want to drop in a set of cams to "go faster" and it so often leads to disappointment.
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
Often times that's the case. Giving up power somewhere to gain it elsewhere. There are exceptions tho as I mentioned.
Not sure about in your world...
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Originally Posted by mickey t View Post
I got it kicked over 4 times in a row...twice last night twice this am...changed my starting procedure...key off start/choke up 2prime kicks..then key on and twist throttle a tiny bit n she kicked over on the 2nd kick each time...
Sent from my SM-J260A using Tapatalk
What a concept...
Get it warmed up proper when you get your clutch fixed and then set your idle speed. Sounds like your getting it now.
