0 Getting Hammered
Last Post: kltrkmpf
0 Leineweber camshaft
Last Post: chevelle
0 question for our machinists
Last Post: JonesL
0 More oil return questions
Last Post: Scott
0 WTB: Sportster Shift Lever
Last Post: tussuck
0 Mid or forward controls.
0 2015 sportster charging
Last Post: Scott
0 Cheap 7200B bearing = NO!
Last Post: Roane
7 Ironhead yes or no
0 New Member and a question
0 piston rings
Last Post: Sprtstr1200s
0 New member softail rim laced to sportster hub
0 Cold weather pants:
Last Post: RDHenley
0 Electrical question
Last Post: RDHenley
2 Humble pie
mickey t's Avatar
mickey t mickey t is offline
Sportster/Buell Model: ironhead sporty
Sportster/Buell Year: 79
mickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud of
What compression tester are you using? It it doesn't have a schrader valve in the end of the hose that screws in the head, it's going to read low.
Part 3612 Innova tester from Advanced auto..30$
Sent from my SM-J260A using Tapatalk
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
I'd guess you're more around 115 with a properly made gauge then. You're rings might be wore but not as bad as you think.
Originally Posted by mickey t View Post
Ok so didn't open choke...
Hhmmm, I should have been more clear in my previous post. If you are running a Mikuni or a Keihin CV then there is no choke. These have an enrichener so leave it alone. For a carb with a choke the choke is fully open when the choke knob/lever is not engaged.
If the engine is not fully warmed up then 115 is very good
Part 3612 Innova tester from Advanced auto...
In my experience Innova products are very good.
60Gunner's Avatar
Chief of Security
Not familiar with it. Having that valve in the hose at the head is a mandatory feature for at least a fairly accurate reading.
Ok so I'm over the 80 or 90 after oil was added so I'm the thinking rings??...
I once did a compression test where the results came up around 80 to 85. Went to bed and worried. Went for a ride and did it again the next day realizing that I had not opened the throttle for that test. Result went up to well over 120. I do not recall the exact numbers, but I do recall how I felt.
So I say do not jump to any conclusions until after you have had an opportunity to do the test at full operating temperature
mickey t's Avatar
Gotcha...but now it leads me back to square 1...why is it so hard to start...
Hopalong48's Avatar
Hopalong48 Hopalong48 is offline
Sportster/Buell Year: 1966
Hopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to behold
Difficult to start, I didn't see that part. Better put that at the top of the list..
Sent from my SM-G975U using Tapatalk
mickey t's Avatar
Yeah that's what led me to do all of this..got a new elec ignition programmed for kick start...takes 20 kicks to start
