0 Getting Hammered
Last Post: kltrkmpf
0 Leineweber camshaft
Last Post: chevelle
0 question for our machinists
Last Post: JonesL
0 More oil return questions
Last Post: Scott
0 WTB: Sportster Shift Lever
Last Post: tussuck
0 Mid or forward controls.
0 2015 sportster charging
Last Post: Scott
0 Cheap 7200B bearing = NO!
Last Post: Roane
7 Ironhead yes or no
0 New Member and a question
0 piston rings
Last Post: Sprtstr1200s
0 New member softail rim laced to sportster hub
0 Cold weather pants:
Last Post: RDHenley
0 Electrical question
Last Post: RDHenley
2 Humble pie
Godown11 Godown11 is offline
Sportster/Buell Model: Sportser
Sportster/Buell Year: 1973
Godown11 is an unknown quantity at this point
Default Sportster
Hey everyone I am new to the iron head community and a young blood rider. Considering this is my first Harley. I have a 73 XLH frame and a 74 XLCH engine with kickstart and electric start. Still has points and has a S&S super e carb. Bike runs great at idle and up to about 25% throttle. If you jab throttle or crack it she pops like crazy. While riding it hesitates and pops then takes off. So if anyone has ideas I’m open to them. Like I said I’m new to the bike so I haven’t been through everything. I redid all the wiring to spec from the service guide.
You should go through all the tune-up basics so you know everything is right.
Ryder Rick "I don't lie without an alibi."
ezmerf's Avatar
ezmerf ezmerf is offline
Sportster/Buell Model #2: XLS
Sportster/Buell Year #2: 1980
ezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant future
If bike set for awhile before you got it with methanol fuel the E is ready for a tear down and a good cleaning and I think this will fix your problem.
Murphy's Law :vvet:
juzyHD's Avatar
juzyHD juzyHD is offline
Bike Builder
Sportster/Buell Year: 1986
Welcome from Slovenia! You should named thread so, that the issue is revealed. It will be better response thet way.
harley506d's Avatar
Sportster/Buell Model: 1200c
Welcome from France!
Better to post your questions in the ironhead section, some good lads on there, and more will see and help.
Give as much bike info as you can.
Highly-Dangerous's Avatar
SPANIARD
Sportster/Buell Model: XL 883
Welcome from Spain!
You can "Check-IN" HERE
CLICK->>"Maintenance is as much art as it is science"<<-CLICK
Nacs Nacs is offline
Sportster/Buell Year: 1976
Sportster/Buell Year #2: 1976
Other Motorcycle Model: K100, XS400, RD250
Nacs is just really niceNacs is just really niceNacs is just really niceNacs is just really niceNacs is just really niceNacs is just really niceNacs is just really niceNacs is just really niceNacs is just really niceNacs is just really niceNacs is just really nice
Young(ish) blood here as well..
Best thing you can do is a tune up and read the manuals.
I opted to keep the points ignition, I like it better than electronics..
If you keep the points, only buy the Blue Streak points set. The JP and other kits are all crap.
Popping from the carb is usually a sign of being lean. Have you adjusted the accelerator pump?
My bike would not even start with older gas, then it would barely even idle. Get the best gas you can get.
Sportster/Buell Year: 1971
Sportster/Buell Model #2: xlh
Other Motorcycle Year: 2011
This thread might be a good read for you.... http://xlforum.net/forums/showthread.php?p=5760054
BTW..... if you could edit your original post #1, and update the subject line with something a little more meaningful..... the next guy reading this thread, 6 months from now, will undoubtedly appreciate it. But, as always, do whatever works for you.
Ferrous Head's Avatar
Sportster/Buell Year #2: 1966
Welcome from the Land Down Under.
I still remember my first ride on an Ironhead. Big Big Grin.
