0 stress killer
0 hi all
Last Post: ironmanx
0 supply oil line seeping
Last Post: hexnut
0 New Member and a question
0 3.5" straight riser
0 Speedometer Interchangeability Between Different Generations.
Last Post: denguy
0 77 XLH Starting issues no needle bearing in primary?
Last Post: MadMike_1126
0 Starter bushing/bearing install in primary cover
0 Keep the V&H head pipes or go stock?
Last Post: 84cj
0 question for our machinists
Mr. Lynn (73), dentat2 (49), OWNED13 (46), knolan.smith (41), Malicious44 (34)
Old 4 Days Ago
mickey t's Avatar
mickey t mickey t is offline
Sportster/Buell Model: ironhead sporty
Sportster/Buell Year: 79
mickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud of
Default Leakdown test
Ok did leakdown test..got a 5/8 18 thread bolt to Put timing hole window to go against the flywheel to keep it from moving...reads 80% leakage front n 85 rear...but I dont hear air escaping? Would I or is it internal? Not sure how accurate this is but. Trying to trim the video so I can post it
Sent from my SM-J260A using Tapatalk
Old 4 Days Ago
CMCSSeabee CMCSSeabee is offline
Sportster/Buell Model: xlh chopper
Sportster/Buell Year: 1970
CMCSSeabee is a name known to allCMCSSeabee is a name known to allCMCSSeabee is a name known to allCMCSSeabee is a name known to allCMCSSeabee is a name known to allCMCSSeabee is a name known to allCMCSSeabee is a name known to allCMCSSeabee is a name known to allCMCSSeabee is a name known to allCMCSSeabee is a name known to allCMCSSeabee is a name known to all
I think you are reading it backards. 80% hold, 20% leakage. A little much, but operable.....
Old 4 Days Ago
I've found the best way to do the leak down test is too remove the pushrods.all valves will be closed tight.the flywheel moving won't be able to open them.
Old 4 Days Ago
+1.
This is how I do mine. I do not like the lock the flywheel technique.
Old 4 Days Ago
mickey t's Avatar
I wish but from the gauge it looks like in not...it has the Mark's on it like food moderate and poor on gauge tha/ reads cylinder leakage...mine is in the red,poor. Which is upsetting because I got it kicked over 5 times...with 11 kicks involved by changing startup technique...took for a run down the street in the rain only to 2nd gear even w the bad clutch n thought I turned the corner w this problem
Old 4 Days Ago
mickey t's Avatar
I have a video but can't figure out how to trim it n post it...I did one not too long g ago by luck...lol
Old 4 Days Ago
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
Just upload it to YouTube and copy the link.
Old 4 Days Ago
Ferrous Head's Avatar
Sportster/Buell Year #2: 1966
If the pisons are moving down in the bore you may nor get a correct reading.
IF you have the piston at TDC of the cylinder your testing it does not take much to stop it from moving. If it's not at TDC it can be a problem.
This is why I suggested you ask someone else who has done one before to help you.
If the engine is leaking air you WILL hear it. But you need to do this in a very quiet area. Often best done at night.
I set the regulator on my compressor to 100 PSI. Some people use 80 PSI. Don't go above 100 PSI in any case.
Take a little time for the gauge to settle when you calibrate it. Try to get as close to zero as you can.
Anything less than 10 is ok. At 20 it's time to do some work.
You might not even be able to hear it if the sealing is really really good.
technically, this test too should be done with a warm engine. But a cold one will tell you if it's really sad.
Old 4 Days Ago
Interesting aside here.
people were talking about how hot an engine had to be to do a compression test. I figure "Operating temperature" of course. I do a number od teadings on my race engine before and after I start it at a meeting. If it's too cold I put a heat gun on it to get the temp up to 75 degrees F. It is VERY hard to start below that.
Today, ambient temp 85 F. I started my 74 Ironhead and let it idle for 3 minutes. Took it for 100 yard ride. Let it idle for 5 minutes.
rear cylinder head temp was 245 degrees.
Now that has nothing to do with the oil temperature which is what we all really worry about. But it is what it is.
Old 4 Days Ago
mickey t's Avatar
Pistons are at tdc..stopped the flywheel from moving by running a bolt through the timing hole, carefully...enough for it to touch so it doesn't move
