5 02 Sporty speedometer wiring
0 2002 Sporty backfire through carb
0 Dynojet Target Tune and/or autotune with PV
0 3.5" straight riser
Last Post: whetrick1
0 2015 sportster charging
0 Problem with tuning Fp3 tables
0 Getting Hammered
10 dragpips to muffler pipes
Last Post: smilinbrad
0 Which Battery?
0 Leineweber camshaft
Last Post: slojoe631
0 question for our machinists
0 WTB drag pipes for 2001 sporty
Last Post: Kejobe
0 Wire Tuck with No Tank Lift and No Rewire
Last Post: TheBreeze
0 A Day in the Life...
0 piston rings
Last Post: Nitro57xl
0 more stumble on cold start
Last Post: smm1200
0 Powerraythor conversion
Last Post: saddlebagrail
0 Fat Ironhead?
mdgtmstng (66), robc (54), 09 sporty (51), bimmer10 (49), DougZ (46), mtntrout, JTedd9 (44), blueoval78 (41), Everett (39)
View Poll Results: Cylinder Head Temp, What is too hot
350 deg F 24 32.88%
400 deg F 19 26.03%
450 deg F 19 26.03%
somewhere over 500 deg F 11 15.07%
Voters: 73. You may not vote on this poll
Old 31st August 2008
Fe Head Fe Head is offline
Sportster/Buell Year: 1979
Both Infra-red and thermo-couples are very difficult to calibrate as they are notoriusly non-linear in their response outputs.
Thermocouples produce very low voltages and need to have short leads that are shielded (to picking up avoid stray voltage from the high tension leads ) as well as having their bimetalic tips silver soldered to the head before they can be considered reliable. Their accuracy is affected by the cold junction's reference and the choice of complex curve fitting mathematical functions needed in order to be NIST approved. They can be point calibrated over a very narrow range using common elements in an electrically noise free environment.
As an example place the CHT sensor in boiling water - at sea level it should be exactly 212 degrees F. The voltage produced at this temperature is only about 4 milli-volts. It is a little lower at higher elevations. Next the calibration can be done using other pure elements like Tin which melts at 450 degrees F. Even placing it along side the temperature probe in household oven will give some comparisons at the 300 - 400 degree F range.
Measuring the cylinder head's temperature IMO is best used as a way to monitor the changes that occur rather than determining the absolute value.
It seems that while water will easliy boil off a cylinder head it will not melt tin. The operating temperatures of most ironheads range typically around the 300 -325 dgree F.
The quickest and surest way to cool down the rear cylinder is to take thin sheets of pure copper and press strips over and inbetween the iron fins making each fin taller and increasing the heads surface area and rate of conduction. Much like the radiator effect. These can even be sprayed black to make them blend in better.
Cheers;
billeuze's Avatar
billeuze billeuze is offline
Sportster/Buell Year: 80s
Other Motorcycle Year: 1983
billeuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to all
Cheers;
You know, I wondered about doing just that. Do you know of anyone actually doing this? and the results?. I was wondering how to fasten copper to the iron - mechanically with bolts? or... ? We'd have to ensure good contact between the copper and iron, maybe use a heat transferring compound like what's used to mount transitors to heatsinks. I also don't know if there would be a problem with different expansion rates of copper and iron that would cause the copper to deform and separate from the iron if not mechanically fastened well enough.
billeuze's Avatar
Hmm. I did a quick search on adding copper fins to iron heads. didn't find anything on motorcycles but interestingly, chevrolet started doing this in 1923. It was a bomb, released to the public without adequate testing. One of the problems they had was fins falling off due to different expansions rates.
I wonder how brazing copper onto the fins would work.
The idea is to make pleats/folds using the thin copper sheeting and have the roots of the pleats with fitted with slits or sets of small holes so they can be silver soldered to the non finned areas on the heads.
Expansion differentials are not a problem when only the smaller section of the root is held tight against the cast iron. The important part in silver soldering is using the proper flux. The copper will be conducting the heat away 5 times faster than the iron and 10 times better than steel so the surface area of the copper fin is important after the root areas are silver soldered to the flat valley portions of the cylinder's head.
Again the differential expansions will not pose a problem when just the base or root area is fixed while folding the finned portion over the raised head fins and not attching them but pressing these areas tightly to the iron fins.
It is best to use MAP gas instead of propane and to work outside when silver soldering as the fumes contain cadmium and should not be inhaled.
Good luck should you try it out on the rear cylinder.
Cheers;
Old 19th December 2008
Last year I purchased on eBay an NOS OEM Harley Davidson Cyl Hd Temp gauge part number 75000-69A. Hottest i have seen it is just over 350`. Most of the time on the hiway it is reading quite low, about 250`. The hotter temps are in city riding. Hottest reading was when my electronic ignition was failing.
UPDATE: Had the heads cleaned up, valve stems honed, front cylinder head temp now reads between 300`F and 350`F according to the NOS HD cyl hd temp gauge; same with an IR thermometer. I expect this is because the heads and valve stems, having all the carbon deposits etc cleaned out, transfer heat out thru the fins better.
Test run was in -5`C weather. Have to see what will happen in the summer riding in 30`C weather.
Old 20th December 2008
11B40 11B40 is offline
11B40 is a splendid one to behold11B40 is a splendid one to behold11B40 is a splendid one to behold11B40 is a splendid one to behold11B40 is a splendid one to behold11B40 is a splendid one to behold11B40 is a splendid one to behold11B40 is a splendid one to behold11B40 is a splendid one to behold11B40 is a splendid one to behold11B40 is a splendid one to behold
Default If your cylinderhead temperature is too high
I'd look at my timing and mixture. Old XLCH are timed at 45-48 degrees before TDC and that was based on leaded gas. We used to time them even further advanced for performance. We ran them very rich with high octane gas. With today's modern fuel (Which I hesitate to call gasoline) and smogged factory engines, a big spark advance will raise temperatures. The other side of that coin is being beyond TDC will also cause problems. The spark plug can also be a heat source. Sportsters can run lots of spark plugs. Champion N4-6, H8 etc. mimic HD plugs if I recall, but for rich running oil users, people would put in long reach J12Y and similar Chevy V8 plugs. These stick well down into the combustion chamber and promote heat. So if you are too hot you are probably too lean, and check the timing. Incoming fuel is a real source of cooling for these engines and if they are on the ragged edge in fuel and timing, they idle great, run so-so but are always on the verge of holing a piston or worse. I personally wouldn't get too wrapped around the axle about perceived high temperatures and try cooling tricks, these engines have a 100 year history of working fine. I've had trick heads with half of the cooling fins off, so they're hot? Who cares? When they seize or start cracking, I'll start to worry.
racerwill's Avatar
Sportster/Buell Model: XLRR
Sportster/Buell Year: 91
Sportster/Buell Year #2: 80
500 degrees is definitely hotter than you want......cylinder head temps should be 300-400 degrees....
2 things that could result in high readings are lean mix and temp sensor too close to exhaust port
Ww
master wizard
RIP Mr Jimi
"All The Way"
Campsurf's Avatar
Campsurf Campsurf is offline
Sportster/Buell Year: 1970
Other Motorcycle Model: Triumphs
Other Motorcycle Year: 1964
Campsurf is just really niceCampsurf is just really niceCampsurf is just really niceCampsurf is just really niceCampsurf is just really niceCampsurf is just really niceCampsurf is just really niceCampsurf is just really niceCampsurf is just really niceCampsurf is just really niceCampsurf is just really nice
and two more things that can cause the temp to rise... intake leaks and no air flowing over an air-cooled engine... I have had the front of my exhaust pipes glowing orange in the dark...
Jim
Old 21st December 2008
Hopper's Avatar
Hopper Hopper is offline
Other Motorcycle Year: 1942
In Canada's climate - specaily this time of year - methinks hot cylinder heads is the least of your problems.
If your mixture is right, your timing is right, your oil is right for the temps, these old engines will just keep on going.
I'd be more worried about ice on the road, or carb icing up etc. Godamn eskimoes are crazy riding about the place right now.
Old 13th July 2010
XLFREAK XLFREAK is offline
XLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this point
I recently purchased and installed a Dakota Digital SpeedoTach on my 1200N. One of the things it does is monitor cyl head temp through the ECM. My temps have been in mid-300's most of the time but will climb to a little over 400 while on the freeway or 'other' high speed riding. And when I slow or stop, the temp will immediately drop to mid to low 300's again. Hope this is helpful even though this might be the wrong thread.
