0 Getting Hammered
Last Post: kltrkmpf
0 Leineweber camshaft
Last Post: chevelle
0 question for our machinists
Last Post: JonesL
0 More oil return questions
Last Post: Scott
0 WTB: Sportster Shift Lever
Last Post: tussuck
0 Mid or forward controls.
0 2015 sportster charging
Last Post: Scott
0 Cheap 7200B bearing = NO!
Last Post: Roane
7 Ironhead yes or no
0 New Member and a question
0 piston rings
Last Post: Sprtstr1200s
0 New member softail rim laced to sportster hub
0 Cold weather pants:
Last Post: RDHenley
0 Electrical question
Last Post: RDHenley
2 Humble pie
View Poll Results: Cylinder Head Temp, What is too hot
350 deg F 24 32.88%
400 deg F 19 26.03%
450 deg F 19 26.03%
somewhere over 500 deg F 11 15.07%
Voters: 73. You may not vote on this poll
Old 13th July 2010
fergerburger's Avatar
fergerburger fergerburger is offline
Senior Master Bike Builder
Sportster/Buell Model: 71 xlch
Sportster/Buell Year: 73
Sportster/Buell Year #2: 74
Other Motorcycle Model: BT rigid hand shift
fergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of light
I own a 64 Corvair and head temperatures are critical to the life of the old girl. It runs around 300-350F. The sensors for the temp are actually washers for the spark plugs.
The result that head temps are lower at idle is interesting and I wonder if it is true. I know that sitting at idle, the engine heats pretty good. Maybe that's jug heat (no pun intended) I feel down under but there is no doubt the bike builds heat at idle. When you pull away from a long stop light, feel your oil tank, it will feel much hotter. No doubt the oil is pretty hot as it returns to the tank as the flow increases.
Old 13th July 2010
XLFREAK XLFREAK is offline
XLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this point
Typical exhaust gas temperature at full throttle is in the range of 1200F for a wide variety of engines. Actual peak combustion temperatures are much higher, but don't last very long, so it's hard to tell the effect on head temperature. Temperature at the tip of the fin will naturally be less than at the base of the fin. Then you have the oil spraying in the rocker box and running down the passage in the head and cylinder. The head temperature depends on where you are measuring and what the recent load on the engine is.
Old 6th April 2014
simeli simeli is offline
Sportster/Buell Year: 1970
Sportster/Buell Year #2: 69
Other Motorcycle Model: Sportster
Other Motorcycle Year: 70
simeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud of
I have a question, you said you redid the head... did you redo the rings at the same time?
If so what was your break in procedure?
A fresh ring or ring and piston job will net you much higher temps during break in and it will reach those higher temps fairly quickly. This is why I do short heat cycles and watch (feel) the head and cylinder temps closely during break in.
Old 6th April 2014
brianbbs67's Avatar
I have been revived
Sportster/Buell Year: 1961
Sportster/Buell Year #2: 1970
Other Motorcycle Year: 1977
I think its much ado about nothing, these are air cooled engines. Its like the dreaded oil pressure gauge, its always lower than you think it should be, but flow is good, so no problems. Just something else to worry you unnecessarily. Just my opinion.
Old 6th April 2014
first i've,heard of the rear cylinder running hotter. the front cylinder has alway's been mentioned.
Old 6th April 2014
trappnman's Avatar
trappnman trappnman is offline
Sportster/Buell Model: XLCH- old school chop
Sportster/Buell Year: 1973
Sportster/Buell Model #2: 1981 XL
Other Motorcycle Model: Norton HighRider
Other Motorcycle Year: 1971
trappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant future
I'm of the belief the rear runs hotter as well-
I've seen "motorcycle math" and opinions both ways- and feel it comes down to particular bikes
CHOPPERS MC S.E. MINN- Chopper for Life- "Old School" Steve Gappa on facebook
Old 6th April 2014
barefoot barefoot is offline
Senior Bike Builder
Sportster/Buell Model: XR 750
Sportster/Buell Year: 1972
Sportster/Buell Model #2: RR 250
Sportster/Buell Year #2: 1976
barefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond repute
Vincents run colder on the back cylinder, almost always. The factory figured that it was because the rider's legs funneled a bunch of air past the rear cylinder.
Old 6th April 2014
Pan55's Avatar
Pan55 Pan55 is offline
Sportster/Buell Year: 77
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 77
Other Motorcycle Model: 1978 FX Shovelhead
Pan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to behold
rubs the hair on my chinny chin chin...
sounds reasonable.....
Old 6th April 2014
trappnman's Avatar
hmmn- what if you have forwards? then the funneled air, would be right ON the front jug
Old 6th April 2014
Static's Avatar
Static Static is offline
Static is a splendid one to beholdStatic is a splendid one to beholdStatic is a splendid one to beholdStatic is a splendid one to beholdStatic is a splendid one to beholdStatic is a splendid one to beholdStatic is a splendid one to beholdStatic is a splendid one to beholdStatic is a splendid one to beholdStatic is a splendid one to beholdStatic is a splendid one to behold
In this case you would put one leg forward and one leg back to even it out. LOL
