0 2000 up front wheel on a 1999 motorcycle
0 Got me a GPS Speedometer.
0 1958 xlch 883
Last Post: thefrenchowl
5 2000 XL Oil Plug Question to drain ALL OLD oil.
0 77-81 Sportster anyone have a 75002-77 temperature gauge?
0 Early model Sportster rear fenders. XLCH
Last Post: CCC
0 19F+19R vs 18F+18R vs 19F+18R wheels
Last Post: slothy49
Last Post: Michman
0 Iron 1966 XLRTT
0 Hawkeye's 1275 Hammer Performance Conversion
Last Post: wrkdWS6
0 What’s your take on Harleys ceo putting down the sportster line
Last Post: felis
0 1970 XLH Tach cable kinked
Last Post: Doc308
Last Post: AZbiker
Last Post: roccus
0 yost power tube guy
0 Fork Hight Questions
Last Post: AZbiker
0 Old oil in motorcycle question
0 New here - compression test produced meh results.
Last Post: randy3934
0 Ironhead Exhaust Poll
1 SuperStreet 2:1 Exhaust Systems for 2007-'20 HD® Sportster® Models
Last Post: warsawleague
0 1995 XLH 883 gas fume smell
0 is a buell a harley
0 Reed valve
BestCoastXL BestCoastXL is offline
Just tryin' to ride
Sportster/Buell Model: XL883L
Sportster/Buell Model #2: XL883L/1275
BestCoastXL has a brilliant futureBestCoastXL has a brilliant futureBestCoastXL has a brilliant futureBestCoastXL has a brilliant futureBestCoastXL has a brilliant futureBestCoastXL has a brilliant futureBestCoastXL has a brilliant futureBestCoastXL has a brilliant futureBestCoastXL has a brilliant futureBestCoastXL has a brilliant futureBestCoastXL has a brilliant future
Post Help required for Motogadgeting all the Things
Just wrapping up the wiring on my ride. I decided to do standalone electrical throughout, incorporating Motogadget solid state circuitry, Lithium reg/rec charging and Battery and Cycle Electric alternator components.
I cirrently have the m switch mini, m button and m lock installed and functioning correctly. The extra button on my switches serves as a programming button for the motogadget motoscope mini.
I am looking for info for the right connections if using the following with no Harley OEM wiring whatsoever:
Motoscope Mini
m unit
tc88a
oem speed sensor (2005 883L >1275 conversion)
I'm looking for the tach and speed sense connections from motoscope mini to m unit and tc88a
Currently I have it connected this way:
white speedo (mini) to white from VSS
yellow speedo (mini) to brown from tc88a
I had read somewhere that the yellow from mini should go to the pink from tc88a coil harness.
On the motogadget site the pdf for the mini links a whitelist of compatible sensors and shows the 05 as a 3 wire hall sensor. Not sure about that one being 12v or 5v.
What I currently get by changing the impulse filter level is a bike that jumps to 282 km/h rolling out of the garage. It's hilarious and an ego boost but I want it to work right. Is this just a matter of using the teach function?
Help is appreciated. Everything else works.
I'm running the power source for the mini from switched ignition. I read somewhere it should be on one of the m unit Aux Outputs.
sportsterdoc's Avatar
The stock speed sensor is
A. red to red/white to factory ICM position #3, which is 5 vdc power
B. blue to white/green to factory ICM position #10 speed input
C. black to ground
Last edited by sportsterdoc; 1 Week Ago at 18:10.. Reason: 3 wire factory speed sensor is 5 vdc from factory ICM
Just tryin' to ride
A. red to red/white to ICM position #3, which is 5 vdc power
B. blue to white/green to ICM position #10 speed input
C. black to ground
your identifying an ICM and I take that to mean Ignition Control Module. Do you mean the Daytona Twin Tec TC88A?
Position #3. Do you mean pin #3?
My speed sensor came from Drag Specialties and has Red, White and Black wires. Red and Black are 12 volt and Ground and the white is the signal output from the sensor.
Just tryin' to ride
https://www.google.ca/url?sa=i&url=h...AAAAAdAAAAABAD
Just tryin' to ride
I see that the TC88A produces a 12 volt square wave output. Does this mean I need to use a 12 volt to 5 volt converter (usb charger circuit)?
https://drive.google.com/file/d/1hOQ...liFz-qa_i/view
Here's the Whitelist I found that says the 04-06 have a 3 wire 12 volt sensor
Just tryin' to ride
Could I not just use a 95-03 VSS that has the 12volt based output?
I don't know if the 95-03 VSS fits properly on the 2005 engine.
The stock 2005 VSS is driven by 5-volts on that model, but I'm wondering if the internal components of that sensor might also be able to withstand & operate properly with a 12-volt supply, causing a 12-volt output.
Since the 5-volt sensor is not compatible with the motoscope mini anyway, if you can't resolve another option, you might try using a 12-volt power source on that sensor & check the resulting output...
- I'm just spitballing something here...
Don't confuse the Tach signal with the VSS signal.
As to the tachometer, you should be able to take the TC88A output (Pin#2 BROWN Wire) and use that to feed the motoscope input on the YELLOW wire.
For Sportster Tech Info:
Just tryin' to ride
I tried the yellow to the brown and no readout in the scope. I could try the signal wire from the coil harness on the TC88A?
There's a setting in the TC88A configuration to 'Enable Tach Output'.
Do you have that enabled?
Here's the Sportsterpedia section about programming the TC88A:
http://sportsterpedia.com/doku.php/t...k:ref:engctl50
Just tryin' to ride
Ah, okay yeah I hadn't gotten that far into the tc88a. This is good info.
I was prioritizing information and a speedometer seemed more important at the time.
Thanks! I'll let you know how it works out.
Most Quotable Electronics Technician Moment"It's always either something simple or something stupid"
Current Build '05 XL883L -->1275 Basic
1275 Basic Kit, Cometic Gasket Kit, Colony Fasteners
Kit, Extra Plate Clutch, 38tooth Primary, 07+ oil pump upgrade, D cams, Hammer Pushrods, stock heads, S&S Precision Hydraulic Lifters, Hammer CV carb jet kit, Arlen Air Cleaner, DK filter relocation, DK 4 stage EBS
Custom fenders, paint and pinstriping
LiFePO4 Reg/Rec, Upgraded Stator Solid Rotor
TC88A sensor harness, coil, 1.4KW Starter, 4AWG feed, Antigravity Lithium Battery with Restart function, Motogadget: m-unit,motoscope mini, m button, m switch minis, m lock, inverted all-in-one tail light on Biltwell Bobber seat, Custom powdercoated frame with internal wiring, Custom electronics & battery enclosure, Goodridge SS rear brake line
Custom pipes, baffles & brass finishers (LBC) Pursuit Brass pegs and grips, TC Bros Fwd controls
Custom oil tank with brass "non-vented" cap, Black braided AN fitting oil lines
Daymaker LED headlight, Custom LED turns
Best 1/4 mile ET: Don't care
HP: Don't care
Why Mod?: Because Mod Life.
