11 How much did you spend on accessories in the first month?
0 Does 20W60 reduce cam gear noise?
Last Post: XL Dane
0 TC88A EX lower MAP settings
Last Post: ZCarFan
0 No juice, no run, no power, nothing...
Last Post: 81ironhead77
Last Post: fafcpa
0 Hagerty Insurance
Last Post: Pigskinner
0 Poll: Saddlebag Supports
0 magneto twin plug heads
Last Post: marioserafica
0 Fun or money?
Last Post: bill smith
5 Wet Dream, Ever Have One?
0 Down on oil
Last Post: Billy1200
0 1968 xlch
0 blonde, brunette, red?
0 Hamburger drum brake clunk noise
Last Post: nickfracture
0 I'm here to introduce Gristle.
Last Post: apotheon
Last Post: Randy_rots
Last Post: apotheon
0 Wish I had a beach with a ocean
Last Post: Akdawg
10 big bore question
0 Transmission figment
0 Smoke and top end job
win307 (66), JrzyDave (59), WeirdNJ (59), Pigskinner (46), jeepsoldier (44), Virgdog (34), bernardderek, John Titor (22)
Old 10th July 2019
Default Check the Gas
Since most of the USA has been hit with storms, tornadoes, earthquakes, hurricanes, and especially flooding, this year.. I think it would be wise to ask the gas stations you patronize if they check their tanks, for water, more often.
Since gasoline sets on top of water, and the pumps draw 2"-4" off the bottom of their tanks, I'm surprised we haven't heard more complaints of "ill running" vehicles. So next time you go to "Thrifty-Pump" find out how often they "stick" their tanks. If it rains a lot, it should be everyday!
Old 10th July 2019
Hopalong48's Avatar
Hopalong48 Hopalong48 is offline
Sportster/Buell Year: 1966
Hopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to beholdHopalong48 is a splendid one to behold
Most likely the reply to that question would be,"huh?"
Sent from my SAMSUNG-SM-G891A using Tapatalk
Old 14th July 2019
the alcohol absorbs the water
Old 14th July 2019
ChinCactus's Avatar
Only to a point. When saturated the ethanol drops out of solution and collects on the bottom. Called phase separation.
Old 14th July 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
What alcohol? I don't run no stinkin' alcohol. ;P
https://live.staticflickr.com/65535/...c4672303_n.jpg
Old 14th July 2019
By alcohol, I'm assuming you mean "ethanol".
. Water won't mix with gasoline, so as ChinCactus said, it separates completely from the gasoline and the gasoline sets on top of the diluted ethanol. So if your fuel pickup is on the bottom of the tank, it's only going to pull the diluted ethonal into the fuel pump or flow into the carb.
