Last Post: heathkeenan
Last Post: ZCarFan
5 Harley T-Shirts
0 I was at the gym yesterday
0 Ok, talk slowly and use small words LED tail lights
0 Swingarm Bearing Preload Question
Last Post: rocketnorton
Last Post: XL1275
0 Ignition advice
0 Koso hd-01-04 2014+
0 900cc Cylinders
Last Post: Staffords
0 What’s your fuel injected 1275 idle speed?
0 Easy Brackets on 93 Sporty
0 Coil Resistance Question
0 Down on oil
0 Rear sets?
Last Post: bordens
0 Rear wheel alignment
Last Post: v3ko123
0 Sprortster Softail 1200 with Edelbrock NOS
Last Post: Randy_rots
0 Early Sportster Shock Absorber Disassembly
Last Post: soundnav
0 Anyone know normal operating temp?
0 CV carb running way rich!
8 Crankshaft Failure
brakes, switch, switch housing, throttle, wiring
Old 29th December 2012
ZombieKillerThor ZombieKillerThor is offline
Other Motorcycle Model: Yamaha Super Tenere
ZombieKillerThor is an unknown quantity at this point
Default Getting rid of switch housing. Issues with front brake switch
ok. So what I am doing is getting rid of the switch housing on the handle bars. Both sides. I bought a new throttle sleeve, hand grips, controls, etc. My issue is the front brake light switch. you know, that little obnoxious thingy that likes to break? Mine isn't broken, but I am at a loss for where to get it mounted. There isn't room on the new throttle sleeve / throttle housing I have, nor do I see a place for it on the new levers. Has anyone else run into this? My only thought at this point is to not use it. If I do that, can I just cut the wires and tape them off? That would open the circuit so as to not actuate the signal correct? oy veh.
I am also chopping the rear fender but I think I have that fella all figured out as far as wiring goes.
Dirt Hill's Avatar
Dirt Hill Dirt Hill is offline
Dirt Hill is a splendid one to beholdDirt Hill is a splendid one to beholdDirt Hill is a splendid one to beholdDirt Hill is a splendid one to beholdDirt Hill is a splendid one to beholdDirt Hill is a splendid one to beholdDirt Hill is a splendid one to beholdDirt Hill is a splendid one to beholdDirt Hill is a splendid one to beholdDirt Hill is a splendid one to beholdDirt Hill is a splendid one to behold
Maybe I'm totally off here, but if you just cut the wires and tape them off, your brake-light will probably be permanently "on". Gotta somehow get a signal "kill" in there. And yes, fender chop is cake.
04 883c converted to 1250 NHRS/Stage I porting/ Andrews N4 cams / S&S carb
leo's Avatar
leo leo is offline
Sportster/Buell Model: 1250R Hammer Performance
leo is a splendid one to beholdleo is a splendid one to beholdleo is a splendid one to beholdleo is a splendid one to beholdleo is a splendid one to beholdleo is a splendid one to beholdleo is a splendid one to beholdleo is a splendid one to beholdleo is a splendid one to beholdleo is a splendid one to beholdleo is a splendid one to behold
you can get a pressure switch that goes in line similar to the rear, or you can just cut it and seal the wires.
Leo 05 Hammer 1250R Laguna Hills, CA
leo's Avatar
leo leo is offline
the cut wires will leave the circuit open, no lights. the switch completes the circuit.
Rico 05R's Avatar
Rico 05R Rico 05R is offline
JESTER SYNDICATE
Like Leo said...get yourself a banjo pressure switch. Much more reliable than the stupid little electrical one.
I had a crazy little idea while I was showering. extend a piece of the new lever (right where it meets the master cylinder) towards the handlebar and then mount the switch on the new throttle housing (how? I don't know yet). the extended piece would make contact with the switch depressing it and turning the light off. does that make sense to anyone else?
also, leo, I am intrigued by this inline pressure switch. I am unfamiliar with the one for the rear brake. where is it located so I can take a peek at it?
nvm, I looked up banjo pressure switch. It looks like I will become a frequent shopper at the local parts store.
thanks everyone! tomorrow may be a busy day for me.
Rico 05R's Avatar
JESTER SYNDICATE
See here: http://motors.shop.ebay.com/i.html?_...o+brake+switch
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
This is probably your best fix. I thought the wire going to my forwards for the brake light looked like shit so I just did away with it. Just had to train myself to "always" use both brakes. That way the light comes on with the rear brake.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
