0 Phoenix AZ
0 Sprung two person banana style seat
0 Pulley Guard/Cover ?????
5 Speedo/Tach combo for '04 1200R
Last Post: bcinjapan
Last Post: GorilladaHun
0 Stock 1200 or Converted 883 to 1250/1275?
Last Post: vagrant318
0 June 6th, 2020: Ironhead Rider's Gathering, PA/NJ (Spring 2020 G.B.B)
Last Post: mrmom9r
0 Starting issues (No Spark)
Last Post: jimstogs
0 1968 Vin number help
0 Recommended Keihin Jet Sizes ? - 100% Stock XLCR
0 how free is 'freely'? rear drum brake and adjusting nut
Last Post: Mofut
0 FREE download of "No Limits-No Regrets" for social distancing
Last Post: axe
0 Help me with the physics of the Bendix float
Last Post: Mission1
0 Gauge disassembly
Last Post: Bored now
0 DK Custom Billet Tank Lifts - New Sizes & Finish - Q&A
Last Post: sprink
0 Carb debate bendix zenith vs s&s super e???
Last Post: ricusa
adjustment, freeplay, noise, pushrods, top end
Old 6th October 2013
Originally Posted by Lockeshill View Post
One more thing. What is the torque on those locknuts? I had a hell of a time getting all but one loose. Even rounded one a little bit. My Indy wrench must have cranked those bastards on there.
The split locknuts do not have to be very tight; i call it "firm plus a little more". Probably about 10 ft lbs. Have to be careful with a longer wrench as they apply more force.
I think DR DICK has commented on this but i do not recall his explanation or his recommendation.
You do have to be certain that the corresponding tappet is all the way up.
antsap's Avatar
antsap antsap is offline
Sportster/Buell Model: 71' XLCH
Sportster/Buell Year: 1971
Other Motorcycle Model: 1956 FLH
antsap has a spectacular aura aboutantsap has a spectacular aura aboutantsap has a spectacular aura aboutantsap has a spectacular aura aboutantsap has a spectacular aura aboutantsap has a spectacular aura aboutantsap has a spectacular aura aboutantsap has a spectacular aura aboutantsap has a spectacular aura about
I'm with Mick. I used to ApeShit these as well, and was in the habit of rounding them off and replacing them frequently. Now I just snug em and give em another rch or two. They hold just fine, loosen easily next time you adjust, and don't require replacing.
Mosey Mosey is offline
Sportster/Buell Year: 1982
Other Motorcycle Model: FX
Other Motorcycle Year: 1976
When you do run into over-tightened lock nuts, just put a screwdriver in the split and twist a little. They usually unscrew themselves after that. Ya just gotta show 'em who's the boss!
brianbbs67's Avatar
I have been revived
Sportster/Buell Year: 1961
Sportster/Buell Year #2: 1970
Other Motorcycle Year: 1977
I agree, 10-15 ft/lbs, snug plus a little. Rattling noise on an Ironhead are hard to find sometimes. I changed my a/c for a OEM one and rode it hearing a metallic noise. I thought it had to be the ac, but turned out the front pipe bracket nut had come loose! In other words, check every fastener on a regular basis.
Turn both the nut and the adjuster at the same time and they loosen up easy.
2007Low's Avatar
2007Low 2007Low is offline
Sportster/Buell Model: XL1200 Low/TTS/Gronked
Sportster/Buell Model #2: XLCH1000
Sportster/Buell Year #2: 1975
2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all
I like that, good idea.
If your feet smell and your nose runs, you're upside down.
U.S.A.F. Veteran
