Last Post: BWP 5p
Last Post: 11B40
0 Spark plugs
Last Post: RDHenley
4 The no-debate OIL POLL
0 Exhaust pipes
Last Post: bobber58
0 The last of a dying breed...
Last Post: RDHenley
Last Post: motorfish
Last Post: spamer80
0 Air gap
Last Post: Wide
6 SPORTY BOBBER PICTURES
Last Post: Bigshankhank
0 It's me - Kokopeli.
0 A Day in the Life...
0 Crane HI4 ignition question
Last Post: EarlyRider
0 '81 swingarm internals
0 Gel in seat for rigid?
Last Post: Piccollob12
0 New guy from Georgia
0 '81 Gasket/Rebuild Questions
2 Your daily tunes...
Last Post: RDHenley
2 Humble pie
Last Post: Sprtstr1200s
3 Tool roll - what do you carry?
Last Post: Veeflys
Last Post: Bow only
Last Post: FiftySixer
jeffcahill (67), jeebus (52), cdepaola (50), RubenAlonzo (50), chida66 (45)
ironhead, lifters, noise, top end
Old 21st January 2018
andy2175m4 andy2175m4 is offline
Sportster/Buell Model: XLS
Sportster/Buell Year: 1979
andy2175m4 has a spectacular aura aboutandy2175m4 has a spectacular aura aboutandy2175m4 has a spectacular aura aboutandy2175m4 has a spectacular aura aboutandy2175m4 has a spectacular aura aboutandy2175m4 has a spectacular aura aboutandy2175m4 has a spectacular aura aboutandy2175m4 has a spectacular aura aboutandy2175m4 has a spectacular aura about
Default ironhead sporster top end noise - loud ! WTF
I have 79 ironhead sportster XLS, 18,000 miles, and it's making this noise in the engine, a loud tapping sound like a really loose push rod,
If this was a car engine, you'd say it sounded like a bad hydraulic lifter, but this engine has solid roller lifters
using a hose to listen, the sound is coming from the center of the rear cylinder, a clanking, rattling sound, a lot like a tappet
so far i have check the following with no results,
removed, inspected, and set clearance on all 4 push rods, all good, but noise still there
removed front and rear rocker boxes, no wear or slop in any rocker arms, no broken or missing rocker arm endplay springs
removed all 4 lifters, no wear or problems
checked 4 cams for lobe wear and end, play all is good
removed rear head, cylinder, piston, and wrist pin, some corrosion etching of the bore but piston shows almost no, wear fits tight
valves look good, stem tips show even wear, no broken valve springs, no loose spring keepers, no stuck valves
no play in wrist pin, rod end play in crankshaft is .010" well in spec,
what else can I check ?
i cannot figure this out, everything inside the engine looks great, but that noise is loud. I have disassembled engines that were much more worn inside and did not make such a loud noise, its a mystery,
TIA for your ideas !
old dog old dog is offline
old dog is an unknown quantity at this point
would dk customs rocker locker be the answer
Scuba10jdl's Avatar
Sportster/Buell Year #2: 1972
Are your oil lines clear to the rockers?
Not for an ironhead.
http://i.imgur.com/Oe4Ttw0.pnghttps://i.imgur.com/AFv3AMo.jpg?1
