0 1998 883 spits and sputters at around 3000 rpm
Last Post: denguy
0 Wont Fire up!
0 Ebay ****evil knievel bike****
Last Post: gusm2
0 clutch issue
0 Warm/hot kickstart
Last Post: Mission1
0 "S" model specific Q&A
0 N65C or N65A
Last Post: lespaul6
Last Post: Hellbent_4
0 XR mutt race bike progress
0 Top end failure
Last Post: Mission1
0 Rubber mount gas tank part
0 Coil polarity
Last Post: davesz1r
0 '86 xl1100 help hooking up lights
0 old style fender skirted
0 Difference in Clutch Levers 45356-07 vs kit 44992-07
0 Ground Up Beginner Build
Gold951 (69), tujbob (65), tcspannerwrench (54), rondog (51), scootsgal (49), barney27 (46)
cylinder, jugs, top end rebuild
Old 13th September 2018
T_worth T_worth is offline
Sportster/Buell Year: 97
Default Mystery Cylinder Symbol
Im in the middle of a Top end rebuild on my 96' sporty 1200 and I discovered that I don't have the same cylinder jugs as the other sportys in my garage. Can anyone identify this symbol/brand? Its on both cylinders in the same corner. (photo https://ibb.co/cdmH0U)
Glamazon Glamazon is offline
Sportster/Buell Model: xl883r sold
Sportster/Buell Year: 2014
Has it always been a 1200? Could be aftermarket 1200 cylinders
Not sure. I picked up this bike 2 months ago from someone. I think it has 2 previous owners (to my knowledge). The VIN # states it’s a 1200. Someone has installed S&S pushrod kit and some kind of aftermarket valve springs (my bike has 3 springs on each valve instead of the factory 2). Need to check if I have S&S cams too.
So it’s possible these jugs are aftermarket. I just would like to know what brand or what the symbol is/means.
Toejam503's Avatar
Sportster/Buell Year #2: 1981
I think that is a "Graphic symbol" for an A. I've seen it before but can't remember where.
Old 14th September 2018
I emailed a photo of my cylinder to my local HD dealer. They researched it, and turns out. Its a Drag Specialities jug. They said I should I should get drag specialities gaskets, but I had already ordered the Cosmetic gasket kit for my Top end rebuild. Hope the gaskets are fine.
Toejam503's Avatar
I knew I'd seen that symbol before, glad you got it figured out.
Medyo Bastos Medyo Bastos is offline
Sportster/Buell Year: 1966
Medyo Bastos is an unknown quantity at this point
I thought it was an adidas symbol...
Toejam503's Avatar
Subliminal messaging, 'if you can see this symbol, you must be walking','Walk in the best "A" '
Old 15th September 2018
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
There's a company that imports a ton of "replica" products from Taiwan, who then sells to distributors. In some cases the products they bring in are sold under private label deals. So the distributor puts his sticker on the box and then sells to dealers as his own branded product.
That's what this product is. It's sold under four different brand names that I'm aware of, possibly more. Drag is one of those companies. You can go buy the exact same cylinder from V-Twin or Custom Chrome, for example. I've also seen it branded as a Sifton product.
The company that imports it keeps a low profile, and won't sell to dealers. They're an importer and they sell to distributors only. Just figuring out who they were was difficult.
It's a pretty well made cylinder, too. It used to be a good lower-cost alternative to the factory piece. But now it costs almost as much as a new cylinder from HD, at least at the retail level. Popular with Indy shops who would rather buy a cylinder from their distributor with good margins instead of buying parts from an HD dealer at a jobber price.
Click Here to Contact Me
Old 21st September 2018
farmall farmall is offline
Sportster/Buell Year: 73
farmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond repute
Good job researching that foundry mark!
What is the company name?
